I'm pretty sure 33s can run similar wheels to 34s.. I think 32s need to run a little smaller.
33 parts are very changeable with 34 parts also, pretty much same coilovers, strut bars etc, different head though
head is the same, the exhaust cam is different
yeah fair enough,
thats another thing then, if i wanna get a 34 later on (ofcoarse) i can swap all parts straight from 33 to 34 which would be cool.
think i like the chunkyness of the 34 and 33s better then the smaller 32s.
like the massive front bars with the low lips etc.
oh, r32-25t, welcome to sau newcastle haha.
Mine could be pretty low by that time, but with storage issues it may not be haha
Good roads and good fun.... Will post pics and get your feedback! 2 Min Noodle reckons we'll be right
I could have brough out the E90 Corolla for some spirited driving...
1.4L Motor with Carby + FF Layout = Win.
Where's a good brake place around here? Might get some rear brake pads
I want QFM a1rms, dunno if anyone would have them around here
Just get them through GSL Rallysport mate! Cheap and easy to deal with.....
I am only running the HPX on the rear as its only going to get the occasional track thrashing!
Yeah its just a 500degree not 600 i think but has better cool temp properties....... Our cars are really heavy on the fronts so i will run the bigger better pads etc on the front!
Yeah fair enough, I got stock pads on the back, should I expect a good upgrade from these??
Your not pushing the limits of the rear brakes on the street so not really, however you may get an advantage on Wakie, more so the pedal wont fade as quickly.........
Ive hand Endless brakes since ive had the car and they havent faded once, been amazing brakes! But rears are finally gone!
    • Hi guys . Can someone help me  I bought an Android screen for my Nissan fuga but it won't turn on
    • My guesstimate, with no real numbers to back it up, is it won't effect it greatly at all.its not a huge change in position, and I can't see the air flow changing from in turbulence that much based on distance, and what's in front of it. Johnny and Brad may have some more numbers to share from experience though.
    • Which solenoid? Why was it changed? Again, why was this done? ...well, these wear..but ultimately, why was it changed? Did you reset the idle voltage level after fitment? I'm just a tad confused ~ the flash code doesn't allude to these items being faulty, so in my mind the only reason to change these things, would be some drive-ability issue....and if that's the case, what was the problem? Those questions aside, check if the dropping resistor is OK ...should be 11~14 ohms (TCU doesn't throw a flash code for this) ~ also, these TCU designs have full time power (to keep fault code RAM alive), and I think that'll throw a logic code (as opposed to the 10 hardware codes), if that power is missing (or the ram has gone bad in the TCU, which you can check..but that's another story here perhaps).
    • Question for people who "know stuff" I am looking at doing the new intake like the one in the picture (the pictured is designed for the OEM TB and intake plenum), this design has the filter behind the front bar, but, the filter sits where the OEM duct heads into the front bar, and the standard aperture when the OEM ducting is removed allows the filter to pulled back out of the front bar into the engine bay for servicing, a simple blanking plate is used to seal the aperture behind the filter This will require a 45° silicone hose from the TB, like the alloy pipe that is currently there, to another 45° silicone hose to get a straight run to the aperture in the front bar Question: how will it effect the tune if I move the MAF about 100-150mm forward, the red is around where my MAF is currently, and the green would be where it would end up Like this This is the hole the filter goes through  Ends up like this LOL..Cheers
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
