Oh and where you say that diff guy was? Do you have his number??
May as well see how much it'd cost to get my LSD back
Yeah give Aaron a call on 4961 1000... He is down near that Brewery joint off Industrial Drive! Awesome bloke and very helpful! If he wants you to take the diff to him i can pull it out for you man!
Is a 100 cell cat against the law?
No more than anything else on my car :P BUT on E85 mine probably puts out less emissions than your McNugget S15 man
As long as there is a some sort of cat with stuff inside it, it's all good.
Guit-toy was talking about trying to pass emissions testing without a cat on E85 (he was confident he could too :-), but the way the law is written you can't drive without a cat :-(
Edited by wedge_r34gtr
Ill get mine past eventually!
Anthony did pass from memory too......
nah i was told i would have to go to e85 if i wanted to get mine through, so gave up for now.
on another note, i think i may be needing to change ecu's when my car goes in on wednesday, i have a feeling that it doesnt have a nistune ecu, and has maybe just had the stock ecu retuned etc..
Not YOU Anthony :P Guilt Toy Anthony haha........ Didnt think that through did i? :P
Nistune looks like a stock ECU as it IS in the stock case, they cant have tuned it with a stock ECU man....... JEM do NISTUNE and HALTECH so the choice is yours :)
ha fair enough mate.. if it has nistune i will stick with it for now i think, but if not, i will go haltech..
but yea, was curious whether you could tune stock ecus or not.. it must have something, as its deffinately been tuned a little.
NISTUNE allows you to retain stock ECU but you can tune certain things..... Pretty sure you cant tune the stock ones? The boys will know :)
Haltech is the best!!!!!!!!!!!! :woot:
yea JEM want me to crack open the lid on my ecu and send them a pic, they should be able to tell whats in there from that.
i plan to go haltech in the future, and didnt plan on spending the extra 2k+ right now, so if i can hold it off untill the next stage, i think i will. plus they need the car overnight for the haltech which i may not be able to do due to work etc...
will see how i go this arvo pulling the ecu and having a look.
I'm running Haltech :-) so +1 here too.
another great ecu to consider is the link/vipec. I was running one before the haltech and was really happy too (They make the speedo wave at you when you start the car too...just awesome.). Only changed to Haltech as the ecu was incorrectly blamed for a problem. the link G4 also allows you to keep the stock ECU case.
    • My guesstimate, with no real numbers to back it up, is it won't effect it greatly at all.its not a huge change in position, and I can't see the air flow changing from in turbulence that much based on distance, and what's in front of it. Johnny and Brad may have some more numbers to share from experience though.
    • Which solenoid? Why was it changed? Again, why was this done? ...well, these wear..but ultimately, why was it changed? Did you reset the idle voltage level after fitment? I'm just a tad confused ~ the flash code doesn't allude to these items being faulty, so in my mind the only reason to change these things, would be some drive-ability issue....and if that's the case, what was the problem? Those questions aside, check if the dropping resistor is OK ...should be 11~14 ohms (TCU doesn't throw a flash code for this) ~ also, these TCU designs have full time power (to keep fault code RAM alive), and I think that'll throw a logic code (as opposed to the 10 hardware codes), if that power is missing (or the ram has gone bad in the TCU, which you can check..but that's another story here perhaps).
    • Question for people who "know stuff" I am looking at doing the new intake like the one in the picture (the pictured is designed for the OEM TB and intake plenum), this design has the filter behind the front bar, but, the filter sits where the OEM duct heads into the front bar, and the standard aperture when the OEM ducting is removed allows the filter to pulled back out of the front bar into the engine bay for servicing, a simple blanking plate is used to seal the aperture behind the filter This will require a 45° silicone hose from the TB, like the alloy pipe that is currently there, to another 45° silicone hose to get a straight run to the aperture in the front bar Question: how will it effect the tune if I move the MAF about 100-150mm forward, the red is around where my MAF is currently, and the green would be where it would end up Like this This is the hole the filter goes through  Ends up like this LOL..Cheers
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
    • Pull codes via the self-diagnosis procedure. As far as I can tell this is just a sign of transmission issues but not a code unto itself.
