I have some old stereo gear i wanted to put into my car but still enjoying the sound of spool etc on the odd time i get to drive the damn thing :dry:
there links to google images, they dont work?
Yeah they work but it required me having to click on it and that is WAY more effort that i was willing to put into it :P
what sound system?... taking a weight saving page from benji...
Lol.. Ask Benji what you can do to save weight in your 1990's/ 2000's non accident Japanese nostalgia vehicle..
I just have some Sony cd player clarion speakers and some rubbish amp..
Thinking of ripping them out for weight reduction.. Lol..
When I had my S13, I was planning to order some quality Pinoneer sound system stuff.
They produce good quality gear from what I've heard....
If you get a double din headunit, you can run the HKS camp system off that :woot: ...which eliminates the need for gauges.
My factory Cd player has locked me out and wont accept the pin code I found in the manual. Faceplam.jpg :domokun:
win!!!!
the last owner striped the sound system out of mine...i just never bothered to install a new one lol. But....i do plan to install a car computer and a decent set eventually, but i know nothing about speakers etc
I like the way the last owner thinks.
I am going to remove my boot carpet for Stage 1, Stage 2 required NOT eating 14 pies every time me and Chookie go past Pie In The Sky.............. Stage 3 TBA
Please note, Stage 3 is not for Amatuers and for offroad use only!
DIF - can you modify your signature to remove/modify the c*ck word in your sig - my net nanny at work freaks out whenever you post
:laugh: WTF is a net nanny?
Stage 3 is taking a dump before going for a drive (typically deletes 1-2kg of mass)
Or in your case having any sort of coversation and dribbling 1-2kg of shit :P
Done..
Bloody nanny goats...
Quality post for weight saving right here guys!
Net nanny - stops people browsing porn and bad things at work - ours is actually called web Marshall
Btw I've had to switch to my phone
If mine did that i would have nothing to do but work! That would be super gheeeeeeeeeeeeeeeeeeeey!
Do you use the mobile version or full version on your phone? Mobile version has a few little bugs that shit me!
Lame!!! If I want to browse sexy ladehs at work wastelands or shock mansion lol..
thanks DIF :-)
NP
    • My apologies. I forgot we were talking about weird beard M series stuff. Had been talking elsewhere with someone about an R33 with similar subject and got confused.
    • Nope, I don't like the look of ND RF, or any ND really, I don't like their faces or arses, why, because of their "modern" lines, the NC, whilst "modernish" has a more rounded shape that I like Well, that's how my overly judgemental eyes see it anyway
    • Should be more than fine, especially the overall fuel pressure would never exceed 3.5bar (assuming that thing never gets more than 0.5bar of boost in stock form). According to the chart, it's 11amps.
    • I definitely know the first rule here, look first, ask second. I've seen many people get roasted 😂 I found a few diagrams for the RB, but I'm yet to come across one for the VQ. From what I have read, the pump gets the +12v along with the FPCM, and it's the negative wire that gets passed through the resistor to regulate the voltage. So I assume I can just ground the negative wire at the pump to eliminate the FPCM control. But I really wanted to see the VQ circuit diagram first to make sure I understood it correctly. Once the new pump is in I'll do some testing to see how it behaves, and in the meantime, I'll keep looking for a wiring diagram. Thanks for your help mate, your time is greatly appreciated.
    • Maybe? I have the Supercheap ToolPro low thingo. It has a somewhat smaller diameter lifting "bowl" than you would expect on a workshop grade trolley jack, and a split rubber pad to suit that diameter. It clears the "N1" style skirts I have. Probably wouldn't if the jack's bowl and a suitably larger rubber block were in use. Having said that though.....you only need the rubber block to exist on the inner side of the pinchweld, so could carve away any rubber that fouled the skirt, leaving some there for "insurance" </simples>
