f**k me you guys are quick
Started reading through then all of a sudden page 100 has been and gone
Should of just went and posted and beat you all
TL/DR
Dif is helpful
Matt is whoring
Jarred has his rags on
Benji/Pinkeye/Bakmonwhatever is whoring as usual and taking stuff of his car to save weight
I think that's about it
TL/DR
Dif is helpful
Matt is whoring
Pretty much covered it all :P
And yep, working through it in another window.... It's a long thread that I'll finish in the morning :)
FML ok so, just had a look at a few things its not the soround that cracked its the unit thats farked, on the ebays add below, the crack is in the plastic right in front of the return button, and i bet the hick from tas drilled out the hex screws that are in it and thats y it farking rattles, im gona spend a day when i get it back to pull the face off and have a good look at it, get some superglue in under it and stop its all tight.
Benji I hope your not planning to win the standard rwd category.
Yeah, hopefully I'll be able to take out the Std Rwd category if I enter.
I should have a good shot providing all the mods get installed.
Some of the guys at Jdmstyletuning have offered to help me install some mods but I'd have to travel down to Syd. Was thinking great idea, then realised I don't get my full licence for another 30 odd days....facepalm.jpg
Shut up Benji
I can't believe you seriously think you can have a good shot with less power than other cars
    • Hi all,  I am in the market for an R200 longnose diff out of a Z31 300ZX, or S12 RSX, DR30 skyline, or similar, in a 3.9 ratio.  Preferably a late model one with the M12 crownwheel bolts.  The only easy to find advert for one of these was my ad back in 2007 when I sold it on this forum.  I sold the diff as I had sold the car it goes to, but as it turns out, after 18 years I got the car back late last year, so now I'm looking for the diff !  If anyone knows where to find a longnose R200 LSD with the M12 crownwheel bolts, drop me a line at [email protected] - Bonus paid if soomeone comes up with the original diff (stranger things have happened !).  Cheers   Ben D
    • Hi everyone, I used to post here a bit from 2004-2013, when I owned various Nissans, in particular my S12 RSX gazelle, which was sold in 2007.  As luck would have it, after an 18 year hiatus, the car found its way back to me last year, and over the past 11 months I have had the pleasure of restoring it with my kids.  One thing that I am after in particular is a 3.9 ratio R200 LSD for it.  I actually sold the one out of the car here back in 2007 , and it would be incredible if I could track down who I sold it to, so I can see how they have progressed over the years (and to be honest, to see whether I can get the diff back !).  Anyways, hi all and let me know "where are the R200 Longnose diffs all at these days ?  Cheers Ben D
    • Arms will be the same as the G35 or 350Z, but as above, there was a change in the lower control arm where it connects to the ball joint.  That said, you can remove the ball joint cone from your old ball joints and fit them to the new ball joints.  To be honest, I didn't think the ball joints themselves were different. The main ball joint is a bit awkward to replace, you really need to remove the steering knuckle to press out the old one.  Some people have used tools to remove it in place, but it just seemed too hard to get to. If you are going to press out/in that ball joint, then you may as well just replace the bushings in the LCA and the compression rod.  You can buy the compression rod bushing from Nissan, but the LCA bushes, you will need to go aftermarket. Much cheaper than buying the whole arm.
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
