Hey Matt thought I would reply in this thread oppOsed to the cruise one..
Old pac was really good, but hard to see at night.. Very quite though, I was the only one around.. Looking forward to doing it in daylight though!
Cars great, pulls a little harder but is a lot beefier in the midrange, The torque is awesome.. 620nm peaking before 4k rpm...
Very fun!
Got a few of the coast boys to come along and my m8 up ur way with his turbo R31.
Hey buddy.
Just a FYI.
You've blacked out your plate in your sig but not your DP.
Your friendly neighbourhood lurker.
Me.
Very fun!
I ran it at 3am the same weekend i got my car, went down chasing my m8's S15 we had a BMW and a forrester with us to, felt like we where in japan with the trees over the road and shit was awesome.
If you have any of these guys coming that i havent listed please let me know so i can keep an eye on numbers, if it gets pretty big i will need to make a few additional plans to make sure we have parking etc!
Very fun!
I havent done much night stuff there... It would need decent lights thats for sure!!
The improvement is pretty big mate! Good result, and ohhhhhhhhhhh the torques :woot: that is a pretty big number!!!
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
