Yea I thought the tourqe was off aswell tbh... But JEM said it should be accurate, unless I'm doing the conversion wrong of 460 ft lb?...
Does seem rather high though!...
I dunno? I know their mainline dyno reads FtLb and mine made 665 :banana:
No one apperently lol
it was just a general question and statement about r34gtrs
Haha i wasnt sure if it was me or Ant you meant!
The gains for Ants car would be impressive... Would have been nice to see a before and after graph overlayed to see the increase in the mid range :D
http://www.skylinesa...nitto-showcase/
Just saw this, i think i might go down for it.
Yeah a mate wants to go to some motorshow the day before so depending on how that goes as to wether or not i drive down to that too........... It does look good! But Sydney twice is not sounding tempting.........
are you sure its ft/lb...they only came stock with ~420N.m give or take.
If it is - thats really impressive - graph please :-)
Yea 460 ftlb..,
Will post graph when I get a chance. Very busy atm
Hey a question for the 34 GTR guys, where are the stock BOV located and whats involved in replacing them to get teh classic wank off sound as some of u call it? :yes:
take the front bumper off i beleive
should be to the left of your fmic
    • Yeah it is always worth testing and balancing actuators out of the box, just set the pressure regulator on a compressor very low (eg 5 psi) and increase it slowly to see when they both move.....unfortunately while you may be able to adjust the length of the actuator rod to minimise any difference, the actual pressure they move from is not adjustable so you need a well matched pair. And yes, the VCAM is probably contributing; the earlier in the rev range they come on boost and the slower the revs build (I think your demo was in 5th), the more you notice it.  Driving at WOT through 1st, 2nd, 3rd etc you will probably never hear it as any shuffling starts and is over super quickly
    • oh they were with that motor, you need to remove the engine to change the spark plugs (don't have to, but it does make it easier)
    • I certainly fall into the annoyed camp, but glad to hear that if it's happening at low boost then I'm not likely going to blow a turbo and end up with metal shards in my oil. Just feels like it prevents me from really driving it without hesitation and "peak" performance. Wonder if it's the VCAM, it did an impressive job of shifting the torque curve and faster spool, but maybe now it's "too fast" and there's too much air for how open the throttle is.  Based on some other threads, will also do some reading on synchronizing the actuators. They are the default actuators that come on the Garrett's and I would think they would be set the same coming from the factory, but if the turbos don't actually work exactly the same way at the same time as previously mentioned, it would be worth making sure the actuators are actuating together properly
    • I went down this rabbit hole before, ended up sourcing a motor from the UK (I'm in Japan) which also didn't function correctly. With the original motor, I disassembled it and reassembled it and it works somewhat, sometimes. What I could deduce from all my screwing around is that there is calibration of the gears on the inside of the motor and two ramps on the main gear which activate switches that operate the motor and move the sunroof either to retract into the roof or tilt. Where I got stuck was that, it seemed in my case that one or both of the switches that are activated by the ramp on the gear did not always activate and thus the motor did not move, causing it to sometimes not retract or tilt (apologies, I've forgotten which way it didn't work.).  Of course this part is discontinued at Nissan now, it's the same part in the S15 but no other models. I also contacted the manufacturer of the component for schematics - forgot the name, they're based in Gifu - but they declined to share the information due to being bound by an NDA, sadly. Looking through my pictures now, it seems I last had a crack at this in 2022. See, I so kindly wrote "open" and "close" next to the switches. If you figure it out, please do tell me. Those little switches, with the red buttons may need to be replaced.
