Once loan is done, let the mods begin.
yeh after loan im doing turob's ECU, cooling system (rad/FMIC) and going to boost to 20-25psi on the built engine go for 400kw at wheels, will have to do fuel management to.
Yeah once i get some debts paid back i am re-doing my damn paint as its Farked! Then going for 400kw too :D
400awkw response monster i'm keen for someone to try -
ceramic coated -9's
twin 3" dumps to full 4" exhaust
ceramic coated ported n1 manifold
Ported and polsihed head
260x9.15 poncams + adj gears
4 or 5" twin entry cooler
ID2000's
E85
I rekon that with a decent head guy and tuner that combo should just hit 400awkw
you could also add vct or vcam for fun.
ceramic coated -9's
ID2000's
E85
Nice!
ill probably blow the farking engine again once i get near 400kw and then ill have to do a propper race build and not a street build lol
Stock internals FTW :woot:
Look at the shit my car has been through and at least the engine is still together, epic lean outs, running with torn air filter, super oil temps! Loves it!
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
