Yeah just a bolt on cooler.
Thanks for your help mate, mine should be coming in the mail today and I might be able to have it together tonight.
After doing 3 days worth of dishes and watering the lawn :(
Well see :P
Good luck with it man! You've got until Saturday night! I was down covered in E85 this morning getting things sorted, the billet filter is clean..... Fuel pump coming out tonight for a check :/
Haha good stuff man, just don't drink any!
It won't take me to long, it's just refitting the front bar will take a little while. Everything else is done just gotta fill it with oil eeeep
LOL Ocsober so NO E85 this month haha
Dude, front bar = 2 cable ties and 2 10mm screws :P
Should really run inner guards again one day but until the car is sorted ill just keep em off :P
Engine not in car yet, getting a bit nervious about it being ready for the cruise, told them im coming to pick it up friday after lunch.
Keep in contact with them regularily without getting to the point where they get the shits...... I've been on the side where your chasing but ALSO been on the side of being chased, there is a limit you can take and it gives you the shits after a while BUT i like your dedication, we all want the car to make it for ya :thumbsup:
I have been waiting around 3 months now i think, there. has to be a limit on how long u can take to rebuild an engine but yeh, im just getting a bit fed up with all the small setbacks
That's fair enough tho mate
f**k yeah, got everything fitted and tight and took her for a run, peak hour traffic then some red lines in a 100 zone, did not hit over 90 degrees (first line on gauge) farkin winning!!!
in other news, is benji being less of a douche because hell be perma banned or because hes cottoned on that we dont like him being a douche?? if its the second one, well done benji, i may come to accept you as an sau newcastler if you keepup your nonstupid posts and trolling!
R34's are a bit too fancy for my liking...
My favourite Nissans are the S13 and R32 GT-R.
S15 is also too fancy for me, as it feels way too new for my liking.
Thinking of just selling S15 soon, as so tempted to replace it with an S13 (would import one from Japan).
Old chassis's such as S13 and R32 GTR make things seem a lot faster.
Sil80 is one of my favorite cars for sure!
Your s15 would be a lot quicker though.
Later model car would be much better for daily use too! Benji just stick to what your doing with the car :)
Good work J-Rad... If you have time come over Saturday and help get some of these cars sorted for the cruise :D As i have to do a few things on mine now too :P
Updated the cruise list the best i could, there is still some unknowns and not everyone turns up to cruises they say they will so who knows :)
    • Hi guys . Can someone help me  I bought an Android screen for my Nissan fuga but it won't turn on
    • My guesstimate, with no real numbers to back it up, is it won't effect it greatly at all.its not a huge change in position, and I can't see the air flow changing from in turbulence that much based on distance, and what's in front of it. Johnny and Brad may have some more numbers to share from experience though.
    • Which solenoid? Why was it changed? Again, why was this done? ...well, these wear..but ultimately, why was it changed? Did you reset the idle voltage level after fitment? I'm just a tad confused ~ the flash code doesn't allude to these items being faulty, so in my mind the only reason to change these things, would be some drive-ability issue....and if that's the case, what was the problem? Those questions aside, check if the dropping resistor is OK ...should be 11~14 ohms (TCU doesn't throw a flash code for this) ~ also, these TCU designs have full time power (to keep fault code RAM alive), and I think that'll throw a logic code (as opposed to the 10 hardware codes), if that power is missing (or the ram has gone bad in the TCU, which you can check..but that's another story here perhaps).
    • Question for people who "know stuff" I am looking at doing the new intake like the one in the picture (the pictured is designed for the OEM TB and intake plenum), this design has the filter behind the front bar, but, the filter sits where the OEM duct heads into the front bar, and the standard aperture when the OEM ducting is removed allows the filter to pulled back out of the front bar into the engine bay for servicing, a simple blanking plate is used to seal the aperture behind the filter This will require a 45° silicone hose from the TB, like the alloy pipe that is currently there, to another 45° silicone hose to get a straight run to the aperture in the front bar Question: how will it effect the tune if I move the MAF about 100-150mm forward, the red is around where my MAF is currently, and the green would be where it would end up Like this This is the hole the filter goes through  Ends up like this LOL..Cheers
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
