hey so apparently its my turn to organise a cruise!!!!
throw up ideas!! id like to do maybe west? north would be to hard to coast boys im assuming.
ill do some research as to where to go, while still basing it around an xmas theme hahaha.
if you got ideas let me know! only lived up here for 9 months and have rarely left newy so im fresh.
even for the drive bys?
because it don't look it..
It's an 80 zone... Was doing 40 across the bridge...
But I do get what your saying.... Happy to set it to private BUT my phone won't let me
think it was a 90 zone and everyone was in second gear?
dunno, im sure theres been worse videos posted on here haha. video the maq pass cruise for example, or putty road which all the execs attend. this was nothing compared those cruises, everyone was very well behaved
I've got a few but might need to spend a day driving to check them out
I'm a granny,this cruise was all above board,is any one saying diff,
I saw no stupid shit happening,was a top day.Every one enjoyed cruising.
Just spoke to Norm, he is keen to come along.... He wants to go to Scone I think he said
Remember the HWP saw all of us driving sensible :)
scone is a treck! hahaha
i looked at the road from cessnock to wollombi and then to broke and back to cessnock? might be to spaced out
A lot of the roads are shit mate, do you wanna just go play out on the back roads out here?
yeah i tghought thatd be the case.
yeah possibly? im not to sure haha. its hard when youve never been there.
Well how about I take u for a run through the back roads? We need the Cos Racecar Evo to run so what better than an impromptu mini cruise?
putty road sounds good to me but im up for watever,dunno about the xmas theme thou wats the go with that jarrad lol
There is snow.... Snow is white.... Tyre smoke is white.... So I guess if you look into it, basically Jarrad is a hoon and just wants skids!
(please read the PDS as everything I think or say may be full of shit)
u do have a point mat maybe the snow themes not so much of a bad idea.....track day :whistling:
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
