no rush matt.
Probarly wont get to watch it till next week once i'm off the work connection.
also, I put a photo of my clutch plate in the build thread like you wanted
Awesome, keen to see....
Hey Joel
What's WA car scene like? My mate says it's all v8s and bogans??does it trip you out seeing p players in turbos??
In other news my mate is looking to buy a comodore. In my efforts to talk him out of it he said Japanese cars arent reliable
THE LULZ!!!!!
WERE
BROUGHT!!!!!!!
:no:
Hey Joel
Yep the cash up mining bogan's like there v8's.
The car scene isn't to bad. WA hasn't caught up with the rest of australia with the hoon laws so there's abit more freedom here.
There doesn't seem to be a big skyline scene here though- they seem to be a bit rarer over here. WRX's, however are everywhere and your right - its pretty trippy seeing P platers on turbo's.
(said in Jeremy clarkson voice) - you modified your car and you ruined it!!!
obviously i'm talking about the reliability...i think the car's sweet!!!
(said in Jeremy clarkson voice) I mean really..... How HARD can it be?
Ambitious but rubbish :laugh:
Jeremy is pretty 2 faced with a lot of cars, I've never seen the last one but when he has driven the gtr he rates it so hard. Pretty annoying but this Vid would be accurate.
Ive seen the first two. The 33 Vid last night haha isn't that weird timing!
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
