No way benji, the track is heaps tiring specially in summer. I always get so f**kin drained!!
Will do mathew!
f**k yeah tank!
Ill get tired and the blood will probably give me a headache from hanging upside down in the Gravel trap for extended periods of time :woot:
And who you calling Mathew ya kent! :dry:
Yeh even the mecahnic was like FFFAAARRRRKKK when we got out of it, it f**king hammers now with the new plugs i cant wait to get a power run done i think i may have to call Mr DVS
I hear he is only doing Mazda 3's now?
:laugh:
Whats this "WE" business white man, i was leading the pack :woot:
U knw he was taking it ezy lol ZOOM ZOOM BOOM :woot:
next cruise looks awesome to, will be great cant wait for the 100km zone with duel lanes will make for some awesome photo's
You will have brakes fitted by then?
Most likely before the nats, just waiting on the rear pads to come in!
Brake install will be slotted rotors, changing fluids, new hoses for calipers, new pads, and new hardware kits.
LOL, why is it so hard to have brakes fitted,
1. call GSL rally sport
2. wait 3 days for pads to arrive
3. call decent mechanic book car in
4 have pads installed.
works 90% of the time 100% of the time
this goes for all the other parts to just add them to step 1 and 2
Edited by T4NK
Turns out I can stay with emmas dad :) cheers mathew ya sweetie!
Some flamin mongrel just parked over my driveway when if he drove 5 metres forward he'd be off it in unlimited parking.
We wrote a note :P
Just have to look out for kangaroos tank. Nearly totally my car :)
I saw the prick with 5 metres to spare, Martin didn't see him I was going 100 and had to go completely on the other side of the road to miss him by around a foot or two.
Butt clenching moment haha!!
QFT
I would have seen it if it came through the windscreen
Your plugs should not have clogged themselves up that quick. I suggest you give a jez a ring to run some diagonistics.
O2 sensor voltage can be checked with the afore mentioned diagnostics or pull em out and if there fouled like your plugs then there Probarly stuffed.
dear heavenly father. twin turbo be thy power, thy kingdom come, tuning will be done, as in aus as in japan. bring to this day four wheel drive and praise our power figures and forgive thoes with less power than us. keep us safe from the cops and deliver us from the under ground, for the GTR32 33 & 34 for ever and ever amen
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
    • Does that German restaurant still exist in the old place out the NW end of Goulburn? When I say "out the NW end of"...I am really being vague. It was 1997 when I was last there, and the only point of reference I can recall is that it was on the opposite side of the main drag from the big merino. And when I say "opposite side of the main drag", I don't mean "on the main drag". It was either a couple of streets back from there, or might have even been out in the sticks a bit further. Was an old farm building or mill or somesuch. And when I say "the big merino" I might actually be thinking of a completely different part of town, because I just looked on maps and the big bugger is not where I remembered him to be! The food was good, consisting largely of various German mystery-meat sausage/loaf things and kartofflen.
    • So while the second sentence is completely correct and the whole point of the conversation, the first sentence bears consideration. If this bloke is just hoping to throw big turbos on and drive it around, because there are no helpful facilities at all in his tropical paradise** then he likely has zero chance of even knowing what the TP is on the last column in the stock maps, let alone know whether the ECU is operating anywhere near it or past it. So the point is very very moot. And, per what I said before, at stock boost on those turbos, you may well be off the end of the map. **I'm just back from Vanuatu, so I know exactly what small Pacific nations can be like wrt paradise without requisite facilities. But it's not even that simple. I put a high flow on my car and had to drive it around without a proper tune because of the lack of opportunity*** to put the bigger AFM and injectors into it to allow it to be tuned. I had to turn the boost down to less than I had before, and back off the boost controller's ramp, because it was exploring parts of the map that it didn't drive in before, and really couldn't access for tuning on the dyno either, and so was pinging. It was still well within the last column, because when I first**** set up the Nistune on the Neo I rescaled all axes of the maps to give some more space to explore. ***Family dyno was broken ****This was 13 years ago, and the TIM thing wasn't a thing then and so TP would definitely grow when pushing past the stock tune's limits.
