Its been pretty dead in here lately....
I had my 50% weighted macroeconomics exam today...didn't even study as I was on 46.8/50 going into the exam, so just breezed through it and think I went pretty well. Soooo 3rd Year of Uni is now OVAHHHHHHH!
Feelsgoodman.jpg!
Freedom/10
Well im not getting -9s anymore, made the payment about 30min after they sold them to another customer in the store apparently, getting -7s with actuators now, should make the same power going for 300-350awkw
hey genelle, im bringing zali with me to ghoulburn as were staying in the illawarra that weekend and her mumma is getting a lift down with a friend.
any tips on dogs on long trips?? how to make them not walk around perhaps? im gunna be layering my seat up with tarps and blankets as to not get piss on my seats! haha
also how often do you stop for toilet breaks?
Sounds dodge. hope you got some money back.
Ha ha,my roxy wears a harness and i clip the seat belt to it.
I also put her soft bed and blanky on her seat,she curls up till i stop.
I stop at ourimba on the way up and she goes to the toilet.
Just make sure your lil doggy has her fave blanky to lie on.
If she's not used to traveling stop and let her out every couple of hours.
Don't feed her before you leave just in case she gets car sick.
Have a great trip. :action-smiley-069:
I worked 13.25 hours today with a 4.15am start and will probably do another 12 tomorrow with a 4.30 start
But now I is going out for tea with the lovely wife as its our first wedding anniversary today
Congrats Mick!!
Where was it?
Forgot I'd got my mum to hide it weeks ago. A mechanic reminded me it was still probably in that same spot. So yes, found it in a battery box lol.
0 day week for me :woot:
Nice!!
Let me know when you're going out to vent the gate! Will come along and show you the S15!
well the -7s are worth more then the 9s, i ended up going with the -7s as i need the turbos now, they will put out the same power as the -9s but the -7s have more top end on them.
I've never seen -7's cheaper then -9's....but just done a quick google...and it looks like the price of -9's have droped off signifcantly. Just don't give them any extra money for the -7's. you paid for 9's, so your doing them a favour if your taking 7's.
what ECU are you going to run?
Yey,got my restrictrive exaust fixed today.
Can't belive how much better she goes,yeehaa.
Not gonna make the treck from newy to the nats now,
no shade any where and i have my lil roxy with me.
Hope to see all you lovely guys before the dec cruise. :woot:
I could be wrong, but I'm pretty sure it's the other way round mate.
Who's telling you this? The seller?
-9s are An updated version of the -7s, pretty much the same response as the -7s but flow a fair amount more. -9s on the same set up make more than the -7s etc...
hey man i just may get an auto if i do get one, city driving in a manual is a dog......
Autos ftw man, get a trans brake too like the cool kids ;)
Edited by Nikk_666
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
    • What sold me on Trailer Park Boys is this scene: Great stuff, just stay clear from the new Netflix production.
