Hahahaha
Didn't think of Jade for Jarred. Stepsons G/F is called Jade
Going to test drive little bird tomorrow up at Ringwood, should be there from 9:00 on if anyone wants to call in and say Hi.
And NO you can't test your car while you are there sorry.
Jade is a cute name for a cute bloke..... No homo lol
What is Lil bird anyway? Can I hate the fark out of ring wood when my fuel system is finished?
Little bird is the new yellow race car Dad bought for me to drive really really fast
If you join the club and have a Cams licence you can have the track to yourself all day for $25
nice one martin!! wish i could!!!
can cars drive on there at all? would be good for some sau newcastle action!!!
I think Matt was looking into something with the club but I have an idea that might work for an event as well
Would require a Cams licence and club membership though but I think you can get them for just a day as well to keep costs down
how much is the club??? i say we all do it :)
why havent we heard of this before? haha.
does aasa license count? >.<!
I was talking to a guy in the club and apparently external clubs are fine but I had to talk to someone and I forgot all about it!! I think we should hook it up!!
Not sure on the aaas licence can find out but
Club membership is $60 from memory and is good for the year
Bonus with that is a few events through the year should get you a start at Matarra as well
Maybeeee with enough interest we can have an SAU class at one of the events
f**k yeah!! but do we need to put a down payment? and do we need minimum numbers? because we wont get any money out of sau i dont think for support.
I know they rent the track to other clubs to run events but cost wise is expensive to get Cams permit etc etc etc
Will ask about a dedicated class to hook onto an existing event if you want
Only cost then will be entry
Forget about SAU.... Just run there as a part of a club.... We should get into it as I am super keen to gate the fark out of Mattara
ahk yeah thatd be best, im keen as :D
put this oil cooler to a bit more use!!
still havent seen you at work owen but if theres a spot next to you i always park next to you if i dont ride the pushy hahaha
yeah i always see you driving out in the arvo as im walking to the carpark you must get out a couple of minutes earlier then me.
i will have to start driving mine to work more.
im gunna try and get a wheel alignment monday arvo cos im putting in a hicas lock bar and a few other bits tommorrrow morning and i will drive it for the rest of the week.
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
