yea the only problem is i need to take out the whole stem, which will require the wheel and tyre to come off. bit of a pain in the ass! so might not get around to doing that for a while unfortunately.
the yellows go together really well.
ah to easy mate, will catch up in the new year sometime.
yea i dont know, will turn out pretty shit i think, or i will get paint on my wheels etc..
see what happens, i may be able to get ones soon then get them fitted when the sway bars go on.
How'd you go with the swaybars man?
haha, thanks but no thanks jarrad! have done all this effort for the wheels, not going to finish it off with dogey painted valves, which i would have to take off the wheel anyways to do a decent job ha.
was very nervous putting the stickers on yesterday, nearly stuffed the first one up. in the end did a pretty good job i think. would be much easier with the wheels off to do that aswell.
good mate, they are sitting in at bowers, my car is booked to get them fitted there first week in jan. very keen!
A
Awesome! You will be happy with the way she handles after that!!!
yea we will go for a run somewhere!
will pass around details closer to the date, but looking at the forth of jan at this stage.
Hmmmm MAY be around for that! Is this going to be a hush hush cruise? :woot:
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
