Either way sounds good.... I was going to be at the Bathurst 12hr race etc but dunno now so cruise is on the cards....
We can use Chookies car as the turnaround point, itll be upside down in the middle of the road kind of like a roundabout :ph34r:
probably aiming it for the 10 of feb? everyone good for that?
not sure on the route though, i had one planned but i think it needs to be done in winter to avoid summer/beach traffic, but it could be ok by feb?...
otherwise do north end of putty, but not sure on a good turn around point? anyone have any ideas?
I may be able to make it not sure yet
Edited by Chookie!!
10th of Feb is my birthday, birthday cruise sounds good to me :woot:
"you both have a barrel at the end of the street to go around, 1st team down and back wins it"
would it better suit you guys the weekend after?
also chookie, hows the car? find something after the run?
So I've got a job interview tomorrow .....
Field Sales Rep.....
Not sure how I feel about knocking on strangers doors to try sell them stuff. Seems like the type of job thatd get you punched in the face.
Also applied for a style assistant job at kotsra westfield in one of the department stores =D =D
Bahahaha best call!
As long as its not Powercruise weekend i should be fine!
If you knock at my door ill punch you in the face............................................... Even if you are not working :laugh: just kidden Benji
i think the wheel alignment is just way out now?
ill know tomorrow going for another wheel alignment :(
If you've gone really low with the coilovers youre going to need adjustable arms to get the alignment right
benjiman
i have all adjustable arms
just need it aligned cause i can see the front are way out just by sight
Ive painted the inside of the house and finished the ceiling since you saw it :D
Oh, i think i found another cloth, sponge furry thingy of yours.... A blue one?
Good stuff, bet it looks a million times better than it did before, now get those floors sanded
Yeah probably mine bring it with you on the 20th if you can
Hello boys,looking forward to seeing all your handsome mushes at the end of the month. :yes:
Not mine you won't , a face only a mother could love is mine.
I'll be in Kempsy on that Weekend for the first round
http://hillclimbnsw.org.au/cal.pdf
If I miss out so be it but I reckon a good turn around point would be the halfway cafe but if I'm not there my opinion don't count LOL
What's a style assistant?
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
