well it's 40deg and i've just spent the the last 2 hours "walking the belts" (lots of steps and steep inclines) at work
I'm stuffed :turned: ...need to get fit
10min break then i'm back out for me :domokun:
Earning the cash and getting fit! You are doing it right!
I work in front of 2 computer monitors all day in AC set to 19.....Are you positively annoyed friend?? LMFA i put u M A D ? and it made it that
Edited by T4NK
lol thats my normal working environment too!!
It's just today my supervisor is busy so i'm taking an auditor around the site...trouble is... its a BIG site (biggest ore shipping terminal in the world).
Nice
Hook a brother up man
I'll walk all friggin day if the money is good
come on joel a couple hours wont kill ya! the boys on the floor do that every day! :P
haha nice one ben
haha lol it actually wasn't that bad...i just wnated to whinge cause it was freekin hot!!!. I've done my time on the floor with the boys...but i must say i'm enjoying the air conditioned office alot more :yes:
anyway, back in perth now for a few days R&R
What's facebook? :-p
It doesn't work on my phone or work laptop...so sau become my only avenue to post random stuff that no one wants to know about while I'm at work lol
Edited by wedge_r34gtr
f**kin oath Chris!!!!
Did you sing out get your tits out????
On another note,
TEAM YELLLLLLLLOOOOOOOWWWWWWWW!!!!!
HAHA, bit keen ay.. yellow red or blue. (If I have swayed to an evo, well see)
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
