just build a drive through one infront of it. front one for cars, rear for parts and tools haha..
This man knows his stuff.
Speaking of sheds i was considering building a massive one with 2 stories in it and having the top floor fitted out as a luxury appartment and under it have a hoist and all the car goodies for my hobbie's. Probably cheaper then a house and would be so farking cool lol.
Think of all the activity space i would have :woot:
Edited by T4NK
That would be good
Just have to have a shit load of insulation and line the insides as would be a sweat box in summer
But I like your thinking
Though to make it really really cool you need a be cent size pool beside she'd deep enough to dive into from the top story
That would be good
screw diving, waterslide or GTFO, but yeh i would have a balcony on the top floor with the usual spar and bbq.
would also do ducted AC and lots of insulation. full luxury spec
next cruise anyone?....
Looks good man! There are some fun roads up there! It is a day trip though.......
There are a lot of potholes, so the lead car needs to be on the ball :)
yea i would mainly be keen to to the part across the top, looks like a main road and is probably good quailty, but im guessing we would have issues with traffic...
ive driven up to gloucester in my car, not too bad bits of road, havent been past there though.
could make a weekend of it and stop in gunnedah overnight haha..
Alex and I used to do midnight runs out the Dungog way, unless its been heavy rain etc its generally pretty good........ A day trip is fine as long as we stop for a decent feed........
Itll give me time to pull over and replace whatever i have broken this time, and also allow Chookie to replace his blown tyres :P lolz
haha, yea. if we were seriously doing it, would be looking at probably a 12hr round trip.
would probably stop at gloucester, then before the national park, then after, then probably after wooten way in buladelah..
epic cruise!
epic cruise!
The Putty run we did a few years back was a long day, we did Old Pac, Galston Gorge, Windsor and then Putty Rd through to Singleton..... It was a 2 fuel stop trip on that run..... On that note, how far is that drive in KM? And have you mapped out fuel stops? (Taking into account that ill only make <300kms to a tank lol
You pair have nothing
You want a long cruise head out through cessnock to broke then take Charlie's road across to putty rd the head out the golden hwy to sandy hollow and turn onto Bylong Valkey way which goes back to Richmond then a short hop to Windsor and back up putty road to singleton and home
I would need to take a refuelling tanker!
From what I saw yeah
And the workers have a real passion for the cars and actually give a shit about making sure its right
Yeah thats awesome! I saw the breif one on the GTR and the passion that goes into them is amazing!
I will bring a spare bottom end, ill have to change that out when u guys fix what u break :ph34r:
    • Hard to say, just pop the rocker covers off and have a look if you think it's cammed. You probably need to replace the valve cover gasket/half moons anyways.
    • From my youth: GTi-R clutch change is a massive pain. The gearboxes are fragile? But the car is super cool and I want one 😢
    • Remember this is 1988 tech.
    • Driveline vibration is resolved. I ended up loosening all my engine mount and trans mount bolts, giving it a good shake then retightening everything and it's gone... Let's just say I was surprised that fixed it.  I've been happily driving it around again but unfortunately put zero time into my direct port/constant pressure WMI setup. I'm on vacation next week, so I'll try and finalize it then.  On a different note, I spent all week fuel/ignition mapping 2x 216L V16 engines. Turbo's were burning glycol and we swapped them out for larger units. We also had planned emissions testing on site, so I figured I'd be there the same week to use their instrumentation and massage any emissions issues out if needed. This was a first for me. Fuel management is similar in certain ways to automotive (i.e air density as load variable) but very different in others. It's all PLC based and AFR's are controlled by air and not fuel. They use a control valve between the turbo and air manifold to control pressure which in turn controls AFR's. Due to this, target AFR tables supplied by the OEM are in pressures and not mass which really through me off. They use air pressure vs fuel pressure tables. I also relied on an O2 concentration sensor the emissions team had in the exhaust. Ignition timing was also all over the place and we were losing a fair bit of power. They're now happily sitting at 16-40BTDC depending on load. We were making about 1600kw at 900rpm at 90% load. Engines were running a lot smoother as well.
    • heh, aint no R32 ever meeting modern targa cage rules unless the driver is veeeery short OP, good luck with the sale, since its already in the land of freedom I'm sure you will find a good buyer.
