plus slab.
pretty f**ked ay, its a bit of f**kin concrete and a few bolts, id do it if the slab wasnt the issue hah
Slab for a shed wouldn't be too difficult.
Excavate down about 200mm to remove the topsoil ....can do this with shovel
Then you'd need sand (for sandbed), plastic membrane, something like SL82 reinforcement mesh, formwork for the edges (you'd use 19 coated formply, 100x50 timber, and hardwood stakes), and then pour the 32MPa reinforced concrete. Then let the slab cure. Slab would only need to be about 150mm thick
yeah dude that's the plan benji
carsales 2000 model in Nsw and tell me mine doesn't look the best and in best nick. leave stupid comments to yourself Luke
a gtt for 13k would be absolute balls ask everyone in this thread they've paid lots for there's
It's very well priced for the excellent condition it's in - i wouldn't drop below this price much.
If i hear of anyone looking over here for a gtt - i'll point them your way.
Edited by wedge_r34gtr
    • That could very well be the thermistor, but the ECU only sees Volts. VDO don't seem to provide a 0-5 volt curve, only the resistance curve.... (or line).
    • Yes. Probably, given that there is only access from the bottom end of it, go with a drill bit. Don't start too small. 7 or 8mm is probably the right size. You want something that can make a big enough hole to do some damage, but not so bit that it clashes with the steel or binds up and breaks your wrist. A slow speed is probably a good idea too. Once the rubber is destroyed, you then have to get the crush tube off the stud, which will be the whole heat/oil/cutting exercise all over again, but this time with the need to strictly avoid damaging the stud (any further than the corrosion might already have done.
    • We replaced the connector just because we could and it was still there, once we swapped the injectors around it stopped. The injectors were something I had thoughts of replacing even before I first started the engine and in hindsight I should have
    • Not too sure just yet, want to have a go at doing what I can myself, but to start with want someone to cast their eye over it tell me what needs doing to get it running and back on the road, so anyone with great overall knowledge would be ideal.
    • I personally would go with cutting out the rubber. Then deal with getting sleeve off separately. Rubber can be painful to cut, it loves to jam up cutting tools. I normally have success with drill bits, deburr bits, angle grinders, jigsaw, reciprocating saw, and never forget... fire. Obviously different tools won't work in all locations you're trying to work with, and you need to be comfortable with each. You personally may be happy slowly slicing it out with a razor blade, if you are, go for it with one too! Feel free to wait for others to weigh in also on their thoughts.
