plus slab.
pretty f**ked ay, its a bit of f**kin concrete and a few bolts, id do it if the slab wasnt the issue hah
Slab for a shed wouldn't be too difficult.
Excavate down about 200mm to remove the topsoil ....can do this with shovel
Then you'd need sand (for sandbed), plastic membrane, something like SL82 reinforcement mesh, formwork for the edges (you'd use 19 coated formply, 100x50 timber, and hardwood stakes), and then pour the 32MPa reinforced concrete. Then let the slab cure. Slab would only need to be about 150mm thick
yeah dude that's the plan benji
carsales 2000 model in Nsw and tell me mine doesn't look the best and in best nick. leave stupid comments to yourself Luke
a gtt for 13k would be absolute balls ask everyone in this thread they've paid lots for there's
It's very well priced for the excellent condition it's in - i wouldn't drop below this price much.
If i hear of anyone looking over here for a gtt - i'll point them your way.
Edited by wedge_r34gtr
    • My apologies. I forgot we were talking about weird beard M series stuff. Had been talking elsewhere with someone about an R33 with similar subject and got confused.
    • Nope, I don't like the look of ND RF, or any ND really, I don't like their faces or arses, why, because of their "modern" lines, the NC, whilst "modernish" has a more rounded shape that I like Well, that's how my overly judgemental eyes see it anyway
    • Should be more than fine, especially the overall fuel pressure would never exceed 3.5bar (assuming that thing never gets more than 0.5bar of boost in stock form). According to the chart, it's 11amps.
    • I definitely know the first rule here, look first, ask second. I've seen many people get roasted 😂 I found a few diagrams for the RB, but I'm yet to come across one for the VQ. From what I have read, the pump gets the +12v along with the FPCM, and it's the negative wire that gets passed through the resistor to regulate the voltage. So I assume I can just ground the negative wire at the pump to eliminate the FPCM control. But I really wanted to see the VQ circuit diagram first to make sure I understood it correctly. Once the new pump is in I'll do some testing to see how it behaves, and in the meantime, I'll keep looking for a wiring diagram. Thanks for your help mate, your time is greatly appreciated.
    • Maybe? I have the Supercheap ToolPro low thingo. It has a somewhat smaller diameter lifting "bowl" than you would expect on a workshop grade trolley jack, and a split rubber pad to suit that diameter. It clears the "N1" style skirts I have. Probably wouldn't if the jack's bowl and a suitably larger rubber block were in use. Having said that though.....you only need the rubber block to exist on the inner side of the pinchweld, so could carve away any rubber that fouled the skirt, leaving some there for "insurance" </simples>
