yeah dude that's the plan benji
carsales 2000 model in Nsw and tell me mine doesn't look the best and in best nick. leave stupid comments to yourself Luke
a gtt for 13k would be absolute balls ask everyone in this thread they've paid lots for there's
sorry, sarcasm doesn't come across in text.
was a lame joke that didn't get picked up.
of course your car looks meticulous.
Glws.
ah I see. thanks buddy sorry for raging thought you were being a Dick haha.
lots of trolls around these parts
s'all good.
I can be the biggest smart arse at times.
as stated, doesn't always come across.
can anyone think of any part they may want off my car that i may be able to take off?
just spoke with chookie, hes got his eye on my sway bars and oil cooler if itll fit.
not sure what else i have but i got all stock parts so i guess nearly anything is up for a good price?
mainly looking at you martin
EDIT
thinking about it pretty sure all i have it the exhaust and wheels haha, everything else has gone into maintenance :P
EDIT
Second in line for oil cooler if no fit chookies car
because the oil cooler is half the size of chookies front mount and i dont have a front mount, der mat ya der brain.
My intercooler is twice the size of Chookie and it fits fine with an oil cooler lol!
How big is the core?
nah no thermo, just flows all the time. just drive real easy on warm up. no turbo spool don't go over 3000 rpm. in winter I was gunna make a cover for it. or take it off for that 6 months.
use to be 130 at wakie and last time was 100ish running temp is usually 90 so works well. running temp isn't any lower which is perfect
haha nope :P
it's f**kin massive and works really well.
still have to find out if it'll fit on an evo. if so I'll hang onto it as I'll need one for it.
how much you after for the cooler?
need a new core(mine has bearing in it), and looking to mount in inner guard, so I should have room.
    • Perfect, I'll get to it this winter then at the same time as I weld on my anti squat kit.
    • Alright so my 32 only has one temperature no matter what degree you set it to. I’ve tried disconnecting the servo motor arm and moving it either direction and got no change. I’ve fixed the leak in my AC and re charged it and with it on and clutch engaged it still blows hot even though the low pressure pipe going to the firewall is ice cold. Both heater core hoses are hot while running as well. Diagnostic code showed 24 for intake air temperature sensor. Anybody got any ideas?
    • I said Garrett style. Not Garrett genuine. And something in the G30 550 range is what you want. Not those pokey little old fashioned T28 sized things. The intake ports in the head are small. There is little benefit in fattening up the runners and leaving ths actual ports small. Just run what you've got. And on the subject of Nistune vs Haltech etc..... You know you can control the transmission with decent standalone ECUs these days, right? No need to keep any of that old Nissan bullshit. Don't get me wrong - I use Nistune on my Neo. But it is a DET, so the number of bodges and workarounds I had to do to make it work in a chassis without ABS, TCS, etc, is quite small compared to the herniated arsehole you will have trying to make it work on a motor that doesn't have some of the things that the turbo ECU wants to see. Just easier to bite the bullet and go aftermarket outright.
    • Hmm. Only when the f**king thing is actually working. Still can't find the leak. And that's with dye being put in the last 3 times!
