nah its not bad but its right of the flared bit of the panel so its pretty noticeable, paint is fine, just little dents, could probably be fixed for cheap idk.
never got a bloody mark on the skyline (off someone else hah)
spewing man, I noticed today someone has reversed into one of my doors because theres 3 dents it didn't have.
people are f**king scum bags
Maybe you should get a brighter colour? :P
https://docs.google.com/spreadsheet/ccc?key=0AjSl31W2Yt-1dFM3bnRBX2QybFpLdHZOQ05pZXlNOGc#gid=0
VERY INTERESTING!!!!
GO GO EVO!!!! no 7 but 8 is just as good, bar is set, I gotta get atleast a 1:08 now hahahaha.
times are from professional drivers and standard vehicles.
ant will like the fastest car
thatll be me going past you benji haha!
though I wont need the gutter.
im going for a cruise on sunday if I can get my oil temp gauge in by that time which I should be able to.
ill swing everyone a msg if I am going, I yhink a few people were keen.
hopefully my brakes show up too so I can bed yhem in a bit
None of my gauges are Hooked up J-rad... Just sitting there all homo :( Still limiter bash it cus I can lolz
Depends when and where the cruise is?
Yeah i am on short range duties too! Full tune should be complete by the start of May... I might have to sit this one out so i can be ready for some track action in May and June...
I would be doing the oil cooler regardless, high boost on pump fuel means heat heat heat!
yeah I really cant be f**ked but:( hahaha
probably will
You will want to be f**ked................. Wait.................. This is not going well......................
What i meant to say is that you would rather do it now than overheat the engine :P
yeah thats true. sigh gotta take the bumper bar off... dem panel gaps brah. benji will hate me!
Benji has the biggest panel gap on the planet!
So does his 2 gayz from toe KO edition nugget from accident damage lol
So if this Homo cruise isnt happening do you all wanna catch up for a feed on Sunday somewhere? Cruise to the bay for Pizza? Hoggies? Stroud Pub?
    • Have you done your thinking backwards? 3 bar, 43.5 psi pressure drop being the presumed specification for an injector, means you need 3 bar upstream when they are firing into atmospheric pressure, and more upstream pressure than that when on boost (you add your boost to your rail pressure to maintain 3 bar across the injector) and you need..... less pressure upstream when you have vacuum in the manifold. So, presuming that you're idling at -10 psi, then you only need ~23 psi in the rail. I realise that I did not need to say all of that to you specifically Matt, once you'd realised your mistake. It's mostly there for complete clarity for others.
    • Have you reached out to the guys at Spool Imports? They are a Ross dealer, I can imagine they would have the rings just sitting on the shelf (I could be wrong).
    • There's one for sale at Grand Auto Wreckers in Lonsdale (SA), for .... let's suggest the sum they're asking for will make you cry. You may have to embrace the idea of modifying the rear subframe to accept some other diff. You could probably find a way to wangle a shortnose into there, with a custom rear adapter and some sort of shenanigans to relocate the front mounts. This has probably already been done by others, so there might be some guidance available as to how easy/impossible it is, out there in the googles. But you possibly needn't restrict yourself to Nissan diffs if you're going to contemplate that. There are similarish Toyota diffs, possibly some Euro ones, possibly some Seppo ones.
    • The ball joint taper and arm taper have to match angle and diameter, but just doing the bushes is a much better option.....seems like the industry moved to "it is cheaper to replace the whole arm than take on the labour for changing this bushes", glad the aftermarket supports it
    • Gee she looks a bit rear heavy in that first pic! Sounds like a great project with the kids, but as I guess you know R series stuff is getting hard to find and pre that is pretty much impossible these days
