I'm not going to SAU Nationals.....
Mechanic said he won't be able to work on my car till January....
and apparently you need these special tools to properly install pads/rotors/hardware kits on an S15.
I dont even care about the other mods, just want the brakes installed so I can drive the thing for when I get my full licence.
"sniff sniff" smells like a rly bad troll to me.
have spent all day so far on the roof of my office and in the parking lot setting up 3 satellites for the NBN broadband system, would anyone like some internets anywhere on continental aus? i can give u internet as long as u can see the sky.
Can i has an internetz!?
haha y can have all the internets u can handle :woot:
Im going to orange as the tech guy with a member of the sales team for some festival they have to promote IPSTAR and sign ppl up so i get to be Mr Internetz God and make sure the systems work for the 3 days we will have then running for.
Car results in. 243awkw at about 15psi I think... Very keen to drive it
Ahh I remember the day when that used to be a big number.. Everyone I know is running 400+ these days
(no offence of course)
    • ..this is the current state of that port. I appreciate the info help (and the link to the Earls thing @Duncan). Though going by that it seems like 1/4 then BSP'ing it and using a bush may work. I don't know where I'd be remote mounting the pressure sender... to... exactly. I assume the idea here is that any vibration is taken up by the semiflexible/flexible hose itself instead of it leveraging against the block directly. I want to believe a stronger, steel bush/adapter would work, but I don't know if that is engineeringly sound or just wishful thinking given the stupendous implications of a leak/failure in this spot. What are the real world risks of dissimilar metals here? It's a 6061 Aluminum block, and I'm talking brass or steel or SS adapters/things.
    • And if you have to drill the oil block, then just drill it for 1/4" and tap it BSP and get a 1/8 to 1/4 BSP bush. The Nissan sender will go straight in and the bush will suit the newly tapped hole. And it will be real strong, to boot.
    • No it doesn't. It just needs an ezy-out to pull that broken bit of alloy out of the hole and presto chango - it will be back to being a 1/8" hole tapped NPT. as per @MBS206 recco. That would be for making what you had in alloy, in steel. If you wanted to do just that instead of remote mounting like @Duncan and I have been pushing. A steel fitting would be unbreakable (compared to that tragically skinny little alloy adapter). But remote mounting would almost certainly be 10x better. Small engineering shops abound all over the place. A lathe and 10 minutes of time = 2x six packs.
