Up for sale are my Garrett GT2860R-5 Turbos. I have upgraded to a big single LAG monster. Still in perfect condition. These were purchased brand new from HP in a box & installed by the team at Powertune.They have only done 10,000KM and have just been checked by Precision Turbos at Wetherill Park. I still have receipts for them with full history and report from Powertune & Precision Turbos.
I'm selling it for $1400 Firm.
Located in Sydney.
https://www.sau.com.au/forums/topic/402643-garrett-gt2860r-5-turbos/
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
