  • Replies 91
Hi Spiro,
I'm missing one of the triangular trim bits that covers the seat belt bolt where it attaches to the b pillar - don't suppose you have it lying around anywhere?
Also, how much for the seat belt buckles that attach to the seat? Delivered to Perth metro (the seat belts I got off you don't fit mine lol)
Cheers,
Steve
^Called C Pillars ^
Diificult to get ones that the backing isn't cracked.
If they have ever been taken out withoiut extreme care they crack.
Thanks for that. Mine cracked without taken out so they might need a replacement. New one cost too much tho.
Yep just paid $160ea from Just Jap (only one set left now), and about the same from RHD (without shipping !!).
HI all.
PM's have been sent.
Does anyone know where the marking and what they are on stock diffs? i know the covers not stock but i still need to pull it out and have a peek.
Cheers in advance
Spiro
HI,
Im back on to stripping the car.
So here are some more pics and prices
Rear Seat belts and buckles $80
Attesa 4wd pump – $120
Attesa 4wd reservoir $40
Peddles - $15 each or lot for $30
Charcoal canister $25
Power Stering canister $15 - sensor lead cut/missing
ABS pump - $80
Drivers side 1/4 glass with rubber $80
Passenger side 1/4 glass NO rubber $40
Dash - $80
A Pillar garnish - $60 pair - Drivers side has 3 holes from single guage pod. will suplly pod also.
Steering column plastic - 4 parts - 50
Boot rubber seal $ 40 Perfect condition
Door/window seals - $ 20 Each please look at pics
Centre vent - $40
Heater/blower/AC boxes - $20 each
Tail Lights - no covers $70 each
More stuff to add.
Rear Cradel Complete
Cradle/Sub frame
Diff (excellent condition)
Half shafts
5 stud hubs
Gtr calipers + pads
Disks
Handbrake assembly
Handbrake leads
Camber arms
Traction control arms
Lower control arms
Tailshaft
Hicas cancel bar
Sway Bar
$800
Great upgrade for a s13 180....
HI,
Parts still avalible
Fuel setup from page 1 - Price Drop - $700
Doors - Price Drop - $150
Stock R32 GTR twin turbos - no dump pipes - Price Drop - $100
Center Din Gauges Price Drop - $40
Boost Sender $25
Side mirrors $50 each
Door cards - Price Drop - $30
Under dash trim with fuse cover - has a little glue residue on left side Price Drop - $20
Front sway bars with links, brackets - Price Drop - $30
Side mirrors - Price Drop - $45
Side Kick pannels - Price Drop - $15
Boot lock liner top bit hard plastic linner. - Price Drop - $15
Driver side rear Seat belt and buckle $40
passenger side rear Seat belt buckle only $10
Attesa 4wd pump - Price Drop - $110
Attesa 4wd reservoir - Price Drop - $30
Peddles - Price Drop - $10 each or all for $25
Charcoal canister Price Drop - $20
Power Stering canister - Price Drop - $10 - sensor lead cut/missing
ABS pump - Price Drop - $60
Drivers side 1/4 glass with rubber - Price Drop - $60
Passenger side 1/4 glass NO rubber - Price Drop - $30
Dash - Price Drop - $60
A Pillar garnish - Price Drop - $50 - Drivers side has 3 holes from single guage pod. will suplly pod also.
Steering column plastic - Price Drop - $40
Boot rubber seal Perfect condition - Price Drop - $30
Centre vent- Price Drop - $30
Tail Lights - no covers - Price Drop - $60 each
Diff cradle complete $800
Accelerator cable - Price Drop - $25
Front Windscreen Moulds - both - Price Drop - $20
Petrol Flap and cap $20
Boot/Fuel leaver with plastic - $15
Rear windscreen wiper motor - $25
Internal roof lights $15 each
Foot rest - $10
Boost Solenoid Boost Valve Sensor $40
Gear stick rubber boots and ring - $25
Aircon controller $50
Boot hinge spring system - $25
Windscreen Wipers $10 each or all for $25
Recirculation pipe $10
Std blow off valves $40
Intercooler pipe left and right ends $25 for both
Glove box $20
Intercooler Brackets top and bottom - note top ones not in pic - not sure what the other ones are $30
Stock ECU $60
Attessa ECU $60
HIcas ECu $60
Stock amp $20
Rear windscreen demister controller box $15
Drivers Side Qtr pannel - Has a liitle rust, I will sand back, and give pics $200
Roof $150 pics to come.
Afew more to add later.
Thanks
Spiro
0414 509 399
