This happened when my timing was out a little bit at cruise loads, after a 15 min drive at 100km/h :) (just an oversight.. thats what you get when you drink too much rum the night before then try tune on V and Pies :) )
I have pictures of EVERYTHING! LOL. Like to keep my work documented.
Edited by gotRICE?
  • Replies 44
Posted Images
Was that timing or Afr's? If so what was wrong Too lean Or 2 Advanced
Wasn't any recommended brands in there.
Also wrt to the boost gauge. Is it going to give an incorrect reading where it is? Or is it just not good to have it there.?
It's on the line that controls the fuel pressure so if it pops off for any reason then you can do some damage.
Try moving it to the back of the plenum against the fire wall just tap into the factor vac line
It will run off a nipple (har har I said nipple)
Heads towards the brake booster into a little black box.
If you cant find it send me a message and I'll take a pic of mine tomorrow
0408 257 613
So if the timing is too retarded then the air will still be in a state of combustion during the exhaust stroke and this extra pressure that usually drives the cylinder down will begin to spool the turbo?
Why would an atmospheric blow off valve cause boost to build in neutral?
Edited by odessy
It won't.
They will all make some boost on free rev. Just not 10psi. More like 1-2psi and that's purely due to exhaust volume and turbine speed. If your ignition timing is retarded it makes the engine work harder/labour more and therefore will build more boost. Probably still not 10psi
^ Yeah from reading 10psi seems to be a bit. I can hear the turbo spooling up so I don't think it's faulty boost gauge. Builds boost gradually until I take my foot of the accelerator. Any idea? Ill try get a video up in the next day.
Still going to check the timing anyways.
Edited by odessy
Well I hope it isn't the timing being too retarded as my CAS has next to no adjustment left to advance it(Almost turned as far counter-clockwise as it can). I haven't had the time to get a timing light and really play around with it yet, just having study breaks and speculating/stressing out.
If the timing is too retarded and I can't advance it far enough, could this be due a mistake being made when the timing belt had been replaced?
Edited by odessy
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
