ok so ever since I got the laurel Ive been curious about the auto head light function.
its on the stalk and theres what i assume is a light sensor on the passenger side of the top of the dash.
how ever when i put it onto auto only the drivers side head light comes on.
thought it might of been the stalk and since I had another one in better condition laying around I swapped it in on the weekend.
but it hasnt made any difference.
anyone know if there is some sort of control box or anythin for the auto lights? or what could be the problem?
its not a big problem as the headlights still work as normal, its just nice to be able to have the factory functions workin properly.
cheers
Danny
https://www.sau.com.au/forums/topic/402830-problem-with-auto-headlights-in-c33/
the sensor for the auto lights is on the drivers side, if you put your had over it in the day while on auto it should light up( dash and what ever is working).
sounds like bad wiring, maybe even at the sensor plug, could even be the sensor.
The auto headlights should slicker on and off as you driver under bridges, tunnels, etc. That's normal.
If its flickering on and off at night time driving under street lights, then your sensor is a dud.
The main sensor is the one on the driver's/right hand side, under the smoked lens. It MAY use the sensor on the left as well.
In theory it shouldn't in any way affect one headlight, it's just a 3-stage switch for the headlight circuit (off/running lights/headlights).
It'll just a bad plug or relay. Mine has a similar little glitch.
Cover the sensor on the dash with something (wallet/phone) (or do nothing at night time)
Turn ignition on, door closed, turn ignition off.
Your auto headlights should stay on until you open the door.
Turn the switch real slow, just in between off and auto, you'll notice one headlight (left) lights up. Also pull the stalk back for high beams, there's a sweet spot just in the middle, lights up left side only, pull the stalk back any further and it lights up both.
Also on super cold mornings, turning indicators on will sometimes make one or both headlights quickly turn off then back on again (bad earth on the steering column?)
Edited by Nic_A31
I had the same issue (one light working in auto) with cefiro no.2. Didn't end up fixing.
There is a brown box plugged into loom behind drivers headlight, think this has something to do with auto headlights and foggies ( maybe) current cef is missing this and foggies and auto headlights no worky.
It's ghey
my left light doesnt work at all tho on auto.
and no matter how light/dark it is outside, when on auto the drivers light only works.
ill have a sus to see if i can find anythin.
i know there is a random box in the engine bay near the drivers head light that ive nfi what it does. i assume it somethin with the lights.
any ideas? i think its green?
scratch that, they do turn off with the ignition :)
if its the tiny green box near the rad thats not it, should be a brown box bolted near the drivers side headlight support mounting.
if that brown box does do some thing with the auto lights it seems you dont have it ?
Edited by Dan_J
    • Hi all,   long time listener, first time caller   i was wondering if anyone can help me identify a transistor on the climate control unit board that decided to fry itself   I've circled it in the attached photo   any help would be appreciated
    • I mean, I got two VASS engineers to refuse to cert my own coilovers stating those very laws. Appendix B makes it pretty clear what it considers 'Variable Suspension' to be. In my lived experience they can't certify something that isn't actually in the list as something that requires certification. In the VASS engineering checklist they have to complete (LS3/NCOP11) and sign on there is nothing there. All the references inside NCOP11 state that if it's variable by the driver that height needs to maintain 100mm while the car is in motion. It states the car is lowered lowering blocks and other types of things are acceptable. Dialling out a shock is about as 'user adjustable' as changing any other suspension component lol. I wanted to have it signed off to dissuade HWP and RWC testers to state the suspension is legal to avoid having this discussion with them. The real problem is that Police and RWC/Pink/Blue slip people will say it needs engineering, and the engineers will state it doesn't need engineering. It is hugely irritating when aforementioned people get all "i know the rules mate feck off" when they don't, and the actual engineers are pleasant as all hell and do know the rules. Cars failing RWC for things that aren't listed in the RWC requirements is another thing here entirely!
    • I don't. I mean, mine's not a GTR, but it is a 32 with a lot of GTR stuff on it. But regardless, I typically buy from local suppliers. Getting stuff from Japan is seldom worth the pain. Buying from RHDJapan usually ends up in the final total of your basket being about double what you thought it would be, after all the bullshit fees and such are added on.
    • The hydrocarbon component of E10 can be shittier, and is in fact, shittier, than that used in normal 91RON fuel. That's because the octane boost provided by the ethanol allows them to use stuff that doesn't make the grade without the help. The 1c/L saving typically available on E10 is going to be massively overridden by the increased consumption caused by the ethanol and the crappier HC (ie the HCs will be less dense, meaning that there will definitely be less energy per unit volume than for more dense HCs). That is one of the reasons why P98 will return better fuel consumption than 91 does, even with the ignition timing completely fixed. There is more energy per unit volume because the HCs used in 98 are higher density than in the lawnmower fuel.
    • No, I'd suggest that that is the checklist for pneumatic/hydraulic adjustable systems. I would say, based on my years of reading and complying with Australian Standards and similar regulations, that the narrow interpretation of Clause 3.2 b would be the preferred/expected/intended one, by the author, and those using the standard. Wishful thinking need not apply.
