Hi crew. Thought you might enjoy some vid from last weekend's tuning day at Barbagallo raceway.
Standard R31 SVD GTS1 on a wet track, with a GTR and Silvia providing some spin...
Love my old 31.....
Love my old 31.....
:down:
wheres the drifting? lol
Edited by w34ponGT
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
