Hey Peeps I have a bunch of R33 parts up for grabs,
I have for sale my Hypergear ATR28 G2 Highflow (R33) Turbo, no shaft play, only used for around 8000km's. Has made 235 rwkw @ 18psi on my R33 GTST with almost stock response.
Comes with HKS Adjustable Actuator (Set to 15psi), and braided oil line.
I also have a 3" JJR Bellmouth Dump/Front Pipe and Apexi Super Suction Kit Intake pipe (2.25" - 3.5")
The dump pipe has a O2 sensor attached (8000kms old) that I will throw in.
I will sell all 3 peices as a kit (Turbo, Dump and Intake) for $850
This will give you all you need for a good free flowing setup.
Or as single peices:
Turbo and HKS Actuator $700
Dump Pipe $100
Apexi Intake Pipe $150 These Intake kits are over 400 bux new
I will post up pics of the turbo with actuator tomorrow night
I also have Powdercoated RB25 Plenum and Crossover Pipe coated by Craved Coatings (SAU Member) Those of you that know Chris know how good his work is. They are coated in silver chrome to give them a polished look without the constant cleaning needed on polished parts. All cast marks have been removed and entirely smoothed out.
I am after $300 for both and I will throw in the BOV (Standard RB25) as it is still attached to the crosover pipe.
I also have a full R33 GTST S2 interior, Front Seats, Rear seats, Front Door Cards and Rear Cards up for grabs.
Drivers seat stitching is starting to come undone in the usual spot but not bad (will post up a detailed pic tomorrow) and front doors cards have a small hole in each for tweeters but generally in very good condition.
$400 for the whole lot.
All parts are in Hills area Sydney, will post at buyers expense but would prefer local pick up for the interior.
Pm me if you are interested and Ill get back to you ASAP.
Cheers
I'm also from the hills, I swear i've seen your car around! Now i know how immaculate it looks under the bonnet!
Will keep an eye out for you / any more parts that come up that i'd be intersted in.
:wave::thumbsup:
You probably have Colin, I have owned it for over 10 years.
The pics posted on here are the old setup, looks even better now :)
That's why I'm selling all this stuff, need to pay for more go fast bits
JJR Dump pipe sold - Thanks Matt
Apexi intake pipe back up for sale - wasn't what buyer was after
Powdercoated plenum and crossover pipe with bov still for sale
R33 series 2 full interior still for sale
Turbo and Intake sold
Still have powdercoated Plenum, Crossover Pipe and BOV up for sale as well as Series 2 Interior.
Come on peeps, buy my Sh1T! Nothing wrong with a bit of bling
  • 9 months later...
    • I'm not going to recommend an EBC pad. I don't like them. Just about anything else would suit me better. I've been using Intima pads for a while now.
    • Agreed, and in particular the earth strap that should go from the subframe to the chassis but it often broken or left off. There is a section in the R32 workshop manual you can follow for troubleshooting if you don't see anything suspicious, and depending where you are (there is no location on your user profile) you should be able to get your hands on a second hand replacement unit still if needed
    • Yeah they mention as a R34 for 2.5 Turbo...but then again thos "small" were also for R34 by that different site. But i look into it and that 310mm EBC is for R34 GTT. And by those you linked the specs are the same 🙂    EDIT: I found these on one site here: DBA 4000 series T3 DBA42304S They are 310mm...and it says are for R34GTT...are there good? EDIT2: ok they have pads too.  What "color" should i get for street use? I dont want/need some noisy ones...(and if they are not that dusty that is good too)
    • Yeah, shame. Maybe  driver's carpet is available 🙏. I am waiting for both amayama and nangun to confirm.
    • Probably. I take it that they are also mentioned to be for R34 Skyline? For example.... RDA has that part as RDA7957. I have the dimpled and slotted version of that on my car https://www.ebay.com.au/itm/285518478694?srsltid=AfmBOopKxMuAFpsxZJdB1cam4D5RAj1f9yJyOttPZLAwXVNCOiwlhrIy This is DBA's top one piece equivalent https://www.ebay.com.au/itm/364246686631?srsltid=AfmBOorbb0XHQgqTvZLgQPhg70nqJtGvdojKnugum3O2LFSr2h-obp8D
