Hey Peeps I have a bunch of R33 parts up for grabs,
I have for sale my Hypergear ATR28 G2 Highflow (R33) Turbo, no shaft play, only used for around 8000km's. Has made 235 rwkw @ 18psi on my R33 GTST with almost stock response.
Comes with HKS Adjustable Actuator (Set to 15psi), and braided oil line.
I also have a 3" JJR Bellmouth Dump/Front Pipe and Apexi Super Suction Kit Intake pipe (2.25" - 3.5")
The dump pipe has a O2 sensor attached (8000kms old) that I will throw in.
I will sell all 3 peices as a kit (Turbo, Dump and Intake) for $850
This will give you all you need for a good free flowing setup.
Or as single peices:
Turbo and HKS Actuator $700
Dump Pipe $100
Apexi Intake Pipe $150 These Intake kits are over 400 bux new
I will post up pics of the turbo with actuator tomorrow night
I also have Powdercoated RB25 Plenum and Crossover Pipe coated by Craved Coatings (SAU Member) Those of you that know Chris know how good his work is. They are coated in silver chrome to give them a polished look without the constant cleaning needed on polished parts. All cast marks have been removed and entirely smoothed out.
I am after $300 for both and I will throw in the BOV (Standard RB25) as it is still attached to the crosover pipe.
I also have a full R33 GTST S2 interior, Front Seats, Rear seats, Front Door Cards and Rear Cards up for grabs.
Drivers seat stitching is starting to come undone in the usual spot but not bad (will post up a detailed pic tomorrow) and front doors cards have a small hole in each for tweeters but generally in very good condition.
$400 for the whole lot.
All parts are in Hills area Sydney, will post at buyers expense but would prefer local pick up for the interior.
Pm me if you are interested and Ill get back to you ASAP.
Cheers
I'm also from the hills, I swear i've seen your car around! Now i know how immaculate it looks under the bonnet!
Will keep an eye out for you / any more parts that come up that i'd be intersted in.
:wave::thumbsup:
You probably have Colin, I have owned it for over 10 years.
The pics posted on here are the old setup, looks even better now :)
That's why I'm selling all this stuff, need to pay for more go fast bits
JJR Dump pipe sold - Thanks Matt
Apexi intake pipe back up for sale - wasn't what buyer was after
Powdercoated plenum and crossover pipe with bov still for sale
R33 series 2 full interior still for sale
Turbo and Intake sold
Still have powdercoated Plenum, Crossover Pipe and BOV up for sale as well as Series 2 Interior.
Come on peeps, buy my Sh1T! Nothing wrong with a bit of bling
  • 9 months later...
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
