  • Replies 92
Fantastic pics as expected, from such as talented photographer.
And that black R34 GTR looks fantastic. Is it God_speeds previous car?
Even in such a big city as this, you can still pick 'em can't you Chris? :)
Thanks for posting up the pics Terry :)
The top two pics in the last one I like very much.
Nice looking Stags Iain & Dale :yes:
Pleasure doing this!!!
And yes, it's mainly when enthusiasts create their own artistry that Matt can capitalise with his photographic skills :)
Nothing in PI that included this stop. ;)
Actually, in a roundabout way there was - even though the location can't easily be made out, an engine bay pic was taken whilst stopped there.
AWESOME! :woot:
I'm stoked that there were some full shots of mine! In the article there was a corner here, and a wheel there; the last day has revealed some brilliant shots; and not just of mine!
I'm pretty amazed Matt got as many shots as he did, given the conditions. :worship:
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
