1989 R32 Skyline GTR
Number Plate ‘RB26GTR’
360rwkw @ 20psi on E85
Price $27,999
I have owned this car for almost 5 years, bought it virtually stock with an exhaust on it. I have either upgraded almost everything in that time. The only part that still remains since the day I bought it is the front pipe, and even that has been modified. Lots of money and love has gone into this car over the years, I have a folder full of receipts for it. I have only listed the performance mods below; it has also been maintained to a high level. The time has come now to sell the car and buy something a little more family friendly.
If you are looking for a well maintained R32 GTR that you can confidently take to a track day and have fun and drive home in it afterwards then this is probably the car for you. My main goal for the past few years was to build a car that was capable of sustaining a day of driving on the weekend and still be reliable enough to drive to work on Monday. I have only done 3 track days in it, and it has performed great. It is still 2.6L which is why I have the number plate.
The car is also fully capable of running E85 as the fuel system has been upgraded and tuned to suit.
The car drives well, and is a day in day out 350+rwkw car. For those that have ridden in this car can attest that it really is a great fast car. So for a 350+rwkw car on E85 that is reliable the price is $27,999.
This is a fair asking price given the work that has been done to it and money spent on maintenance all up totalling over $35k
Engine
Rebuild RB26 – Built by Shaun @ Boostworx in May 2009
CP Forged Pistons
Tomei Metal Head Gasket
Gates Racing Timing Belt
New R33 GTR Crank
New Std Oil Pump
New Water Pump
ACL Race Bearings – Main & Conrod
Reconditioned Head
Tomei Sump Baffle
Tomei oil restrictor
Mines Rocker Cover Baffles
Nismo Engine & Gearbox Mounts – Fitted June 2011
Just Jap Autech Style Catch Can – Fitted Nov 2012
Performance
Garrett 2860-5 turbos – Fitted April 2009
Tomei Poncams Type B (260 degree, 9.15 lift) – Fitted March 2012
1000cc injectors – Fitted Feb 2011
Custom twin walbro intank fuel pump – (similar to Powertune Setup) – Fitted Feb 2011
Custom twin fuel lines to std fuel rail – Fitted Feb 2011
ARC 70mm Intercooler – Fitted May 2011
Nismo AFM’s – Fitted Nov 2010
K&N Air Filter
Nistune ECU – Fitted Nov 2010
Turbosmart E-Boost Street – Fitted Nov 2010
Yellow Jacket Coil Packs – Fitted Nov 2010
Silicone Intercooler Hose Kit – Fitted Nov 2010
Exhaust
Mines 65mm dump pipes
2.75in – 4in front pipe
4in AM Performance cat back exhaust – Fitted Dec 2011
Wheels , Tyres & Brakes
Nismo LM GT2 – 9.5in wide +15 offset
Federal RSR 235/40 R17 – Fitted April 2012 (barely worn)
R34 GTR Brembo all round – Fitted Oct 2010
Braided Brake Lines
Slotted Rotors
QFM HPX Brake Pads all round
Suspension
Tein Super Street Coilovers – Jap Spec – Fitted Dec 2008
Hicas Lockbar
Rear Subframe Whiteline Pineapples
Whiteline Rear Adjustable Sway Bar – Fitted Dec 2008
Super Pro – Adjustable – Rear Upper Control Arm Bushes – Fitted Aug 2010
Super Pro – Adjustable – Front Upper Control Arm Bushes – Fitted Aug 2010
Super Pro – Adjustable – Rear Lower Control Arm Bushes – Fitted May 2011
Super Pro Crossmember Bushes – Fitted Jun 2011
Other
Jim Berry ‘Montyzilla’ Clutch - 9.5in clutch plate, 1.8tonne pressure plate
Clutch engages great, very soft pedal. Was installed Dec 2010 still going strong
C’s Short Shifter
Oil Cooler Kit
Autogauge – Oil Temp
Autogauge – Water Temp
Auto Gauge – Oil Pressure
Stereo
Alpine head unit – MP3 compatible
JBL 5 channel AMP
JBL 12in sub
JBL 6 x 9
JBL 6in splits
https://www.sau.com.au/forums/topic/402964-fs-r32-gtr-360rwkw-on-e85/
  • 2 months later...
  • 1 month later...
    • Wife wanted basket things in the wardrobe in our temporary house. Thought about ripping our the wardrobe and fitting the entire IKEA set, but it's a temporary house and we want to move in a few years. So IKEA advertises this as a 50cm unit, however the actually basket and rails measure 46cm wide. Only issue was depth, IKEA stuff is quite deep, where as the builder special junk is super shallow at less than 40cm. Send it, chopped the rails, then offset the mounting holes, job done, happy wife, less shit scattered all over the bedroom. Did the same to the other side too. Also drove the Skyline shit box today, dropped off oil at Supercheap Auto. I didn't realise they only now take max 2x bottles per visit. I visited 2x Supercheap Autos.
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
