  On 16/07/2012 at 7:47 AM, XKLABA said:
fixed, and yeah that graph can't be scaled right, 20psi at 4800rpm with -9s definitely doesn't sound right
lol ye misread that one ... Just quickly looked :D
CBF'd editing as he'd posted already and knew my meaning
  On 16/07/2012 at 8:55 AM, Hadouken said:
No just a overlay of less boost and more boost. Before and after cams will be up in 2 weeks
Would be interesting to see how she goes with a set of cams (I'm assuming you mean cams and not cam gears?)
It would be good to see some more -9 graphs. Even GT-SS graphs are rare (was searching for these because of the lack of -9 graphs). As far as the 2860's go, -7's and -5's are common as ;)
Here is mine on my old std engine lol will have an updated one in the coming weeks once i get a retune, new engine currently making 329 at 18 with same exhaust less on my 'street' exhaust
Thanks for the graph levinboy...looks like she slipped a bit on the dyno there? :D
hahaha yea was shocked when my tuner told me, should be fun when i up the boost again :P
will post updated results once it has been retuned
  On 16/07/2012 at 11:58 AM, tommis85 said:
That looks like a much steeper ramping up of power than what I've been seeing! ....and driving!!
It's just the graph axis (starting at 0km/h rather than say... 50km/h) that makes it look different.
Nope, meant cam gears
  On 16/07/2012 at 9:44 PM, Manuel Kasko said:
Hypergear SS1PU :D
It maxes out at 250 on my setup but haha
So probably not what your looking for but gives a hell of a punch
Oh nice...I googled them :D I guess that's the other end of the extreme hey? Bet that thing is awesome at gymkhanas and mountain runs!!
    • Absolutely could be. I collected data logs from when the O2 sensor was still out and also after I had replaced it so will try to compare them. Pretty confident that the affect is lowered with the new sensor, will check logs at the same RPMs/conditions.
    • Hey guys Long time lurker, I daily a nm35 stagea 250t rs four and I've had it for almost 2 years (very reliable 馃憣). Issues or just looking for information ill always find myself here having a read, so thought id join.  3inch stainless intake, pod filter, AM performance turbo dump pipe, 3inch hotdog, 3 and half inch stainless to 3 and half inch AM performance blast pipes. Bc racing coilovers. 18inch rims Hdi intercooler and trans cooler soon.  Here's my car
    • thanks for the advice on the box... i was thinking the 6 speed was better for cruising on the highway but on closer inspection and comparison the Rb 5 speed box was not too different...  So the choice is going to be the RB25 box... if I can save up and find one at the right price
    • Thanks Matt, yes that's what i am aiming for. Just going to apply the right voltage and grounds to the dash connector. Hence my search for these pins... any chance you know if these pins are in the same spot as the ones on the S15 Dash connector? as mentioned above on page 8?
    • Yes, unfortunately that's the one. Signal was noisy to begin with; after driving once and looking back at the logs I saw pressure constantly swinging between 0-200psi, or staying at 0 randomly for a few seconds. There's a lot of good sensors that share the same look and feel, so don't presume they're all bad. I bought mine for 20$ off Amazon and I should have read the reviews prior, as it's clear they're junk.  I purchased a lowdollerr motorsports sensor.
