Contact: pm, post, or text 804-239-4047
Price: $1000+ shipping for everything. Individual prices listed below.
I WILL GIVE A $75 FINDERS REWARD TO ANYONE WHO FINDS ME A BUYER FOR THE WHOLE PACKAGE!!!!!
I had this setup on my Rb20 S14. I bought it all new. The XS power topmount has CUSTOM work done to it. Everything has under 500 miles.
Package includes:
-PNT intake manifold (paid $1300)
-PNT 90mm throttle body
-PNT dual feed fuel rail
-XS Power top mount turbo header w/ custom 44mm vband wastegate flange (paid $300+$100 in custom work)
-Custom 44mm vband wastegate dumptube ($75 in materials/custom work)
I will sell the intake/TB/FR for $800+shipping
I will sell the XS Power topmount and dumptube for $250+shipping
I WILL ACCEPT PARTIAL TRADES FOR:
17"-18" wheels 5x114 (with NEW"ish" street tires OR racing tires OR NO tires
FMIC (universal or for a 2g Eclipse)
nice recirc BOV
gauges
91 Ford Ranger lowering kit
^^^yes, those are velocity stacks inside the intake. Exceptional build quality.
how much for the full setup and how much were u making on the 2o?
I only have the fuel rail left. I paid $265 shipped for it, and will let is go for $200 shipped since I have someone interested in just the intake/tb. It will come with three (3) $15 earl's fittings for an added value :) I made 435@16psi on a 60-1 Godspeed turbo. Saw full spool at 3600 rpm, I was really happy with this setup. Power everywhere, pulled like a champ all the way my Bee-r 7200 rev limit.
    • @Haggerty this is your red flag. In MAP based ECU's the Manifold pressure X RPM calculation is how the engine knows it is actually...running/going through ANY load. You are confusing the term 'base map' with your base VE/Fuel table. When most people say 'base map' they mean the stock entire tune shipped with the ECU, hopefully aimed at a specific car/setup to use as a base for beginning to tune your specific car. Haltech has a lot of documentation (or at least they used to, I expect it to be better now). Read it voraciously.
    • I saw you mention this earlier and it raised a red flag, but I couldn't believe it was real. Yes, the vacuum signal should vary. It is the one and only load signal from the engine to the ECU, and it MUST vary. It is either not connected or is badly f**ked up in some way.
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
    • I guess one thing that might be wrong is the manifold pressure.  It is a constant -5.9 and never moves even under 100% throttle and load.  I would expect it to atleast go to 0 correct?  It's doing this with the OEM MAP as well as the ECU vacuum sensor. When trying to tune the base map under load the crosshairs only climb vertically with RPM, but always in the -5.9 column.
