I'd love to but I've been told that I'll only get a couple of laps without an oil cooler, and not much more with an oil cooler. Not sure that I'd want to pay money when I can only push it hard half the time.
It would be good to go with a group of newbies though, don't want to make an ass of myself while running with the big boys. :D
http://www.queensland-raceway.org.au/publi...blic_drive.html
Hey wat the? a couple of lapz without a oil cooler? :)
Oh anyone like to provide more details?
I would love to come... Did a performance drive last monday which was great. Had 4 sessions on the QR full track which was excellent. Car is still stock (have a SAFC2 untuned) and reached 180km/h on back straight and 170km/h front straight. Could go on for hours, la la la.... (have some footage, soon to be in MPG format).
Want to do it again....
BUT.....
Thats the day my first kid is due into the world. I think I would be shot if I went. Would be good to see Melv's car on the track. Would have been interesting to see it up against the 911 GT3 that was there.
Oh well, maybe next time.
im keen as but i cant arrange it as im still a virgin at this stuff
so if anyone wants to brake me in im keen to get out to there.
We used to all meet up earlier and cruise into Q.R. a bit before lunch 11ish I think. You just got to fill out some details to get your Q.R. recreational license then pay for your laps and then get into it. If we all put SAU on the top of our form they will group us together aswell. Looks very cool when you have a grid full of Skylines.
sounds really good to me mate, ( u know how to brake me in easy )
just got to get some sloted rotors next week and ill be completely ready.
well apart from the semi-slicks that will be the last thing.
im so excited !!
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
