Unfortunately for me it has come time to sell my R32 GTR.
The car has a Genuine Veilside wide body kit (imported from Japan at a cost of $6780) fitted to it currently unpainted so it is in Black Gel coat ready for paint or to be moulded in depending on what look you are going for.
It has a large Carbon fiber rear wing and a genuine JUN front carbon lip. I also have a JUN rear diffuser to go with the car if it goes for the right price.
Currently the car has a set of 18x10 Lenzo D1R wheels wrapped in pirelli P-Zero Tyres 265/35/18 all round.
Custom made LED Rear taillights, they are one off items
Has HID fog lights and comes with HID kit for the headlights, which have been converted to H4, Hi and Low Beam in one instead of being separate.
Battery Relocated to Boot with 0 Guage wiring throughout, cut off switch mounted on box.
Suspension Modifications:
Full DGR coil-over suspension to custom specifications, upper pillow ball mount, 30 way adjustable
Front and rear Cusco Sway Bars, Front 24mm, rear 30mm
Rear fully adjustable camber arms
Hicas Lock Bar
All Hicas system removed including all piping and standard power steering lines modified to eliminate complete system.
Stainless front strut brace
Carbon fibre rear strut Brace
Brakes:
Full set of Brembo calipers off an R33 GTR V-Spec With new DBA slotted rotors all round front and rear and ebc green stuff pads.
Engine Modifications:
Full Head Rebuild:
Fully Shimmed lifters with Titanium Shims
Big HKS camshafts, Stepped camshafts, Intake 272deg 10.20mm lift, Exhaust 264deg 10.0mm lift Head has had channels Ground to suit the Hi-Lift Camshafts
Ported and Polished Head,
New Bronze Valve Guides
Ferra Stainless Intake and Exhaust Valves, Multi Angle Valve Machining
Tomei Titanium Valve Springs
Tomei Titanium Valve Retainers
ACL Race series Cometic Head Gasket
All work was completed approximately 2000kms ago
Powder coated rocker covers in Bayside Blue
Full Alloy radiator
HKS Fuel Rail
Seimens Dekka 846 cc injectors serviced, and spray pattern altered by Deutschwerks in the USA
Walbro 255 LHP Fuel pump, 255L per hour High Performance
Huge Greddy Inlet Manifold, Split type
Custom Ignition setup:
LS2 Truck Coil packs
Custom Wiring loom and alloy mount
Custom Eagle 10.5mm leads in Blue
This setup creates 6-10x's more spark than standard packs and eliminates the need for an igniter there is also less stress on the coil-packs as there is air circulation under and around the packs cooling them. Each pack also has a heat sink to allow it to run more efficiently and reduces the chance of failure.
Tomei SUS304 Expreme Headers
Tomei SUS304 Expreme Dump Pipes, The Large type, 92mm outlet
Custom exhaust 'Y' Pipe
Venom 4.5' Hi Flow Cat
Apexi N1 4" Exhaust, Not available in Australia
Nismo LM Turbos, These Turbos are a Hibrid Turbo developed By Nismo for the GTR, They are larger than N1 turbos and have been cleared by CAMS for use in events such as the Targa Tasmania because they could be optioned onto a limited run of cars. They are Group A Nismo GT LM turbos. They were rebuilt and Hi-flowed by Turbologic approx. 7500km ago
Apexi "M's" intake kit
All drivetrain fluids changed with Amsoil Sever Gear and Diff oils changed.
Brass button Clutch
R32 GTR V-Spec Rear differential
Full Bottom end Rebuilt by previous owner with CP Forged Pistons, new rings and an oil restricter has been put into the block to stop the over oiling issue that the early GTR engines had.
HKS Oil Cooler and Full oil filter relocation Kit With all speed flow fittings
Comes with a Tomei Oil pan baffle that is not yet fitted
When the car was Tuned it was running 557.4 Hp at the wheels
Interior:
All systems are controlled by and apexi Power FC with a Hand Controller.
It has an Apexi AVC-R, electronic boost controller with scramble Boost Option
It has a set of Auto Meter Cobalt series Gauges monitoring engine conditions, Boost/Vac, Oil Temp, Digital Oil Pressure and Digital Air Fuel Ratio.
Has a flip out Pioneer AVH-P-5950dvd DVD headunit
German maestro 6.5 inch speakers in the rear, Carbon Fibre cones, Very high end speakers ad a pair of pioneer 6" speakers in the front
I have all receipts for most of the work done to the car, and receipts for most of the parts, some were purchased off forum members from here. Car has rego until september this year.
The Bad Point: In March while driving the collars in the oil pump failed causing a sever drop in oil pressure. This has caused the engine to spin a big-end bearing. Car still starts and drives but it will need to be trailered to avoid damaging the engine further. I no longer have the time to fix the car which is the only reason I am selling
If you have any questions give me a call on 0434817247 or PM me here and I would be more than happy to answer any of them. Also if you would like to come down and see the car let me know and we can organise a time for it.
The car is in Wollongong about 1 hr south of Sydney.
I am taking some pictures today and going to put some up but if you would like pics of specific things let me knwo and send me an email and ill get them to you.
The car has a had a lot of time and money spent on it, looking for $13,000 ono.
Edited by Matnos
Have tried to upload some pics and it says they are too big, if people want to send me their email address i can send you some photos.
Also forgot to mention that the car has a R32 GTR V-spec Alloy bonnet, and evidently adjustable cam gears and gates racing timing belt, just incase people were thinking I was silly having big cams and no gears :-P
Yeah thats correct, i had the choice weather I wanted to ge the other front and rear bars but didn't want to go that way, still wanted a sort of semi stock look still, just fat...
Im surprised that the front bar stretches that far to line up with the guards. Does provide a nice stock / fat look though.
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
