  • Replies 90
Corinne, as Eric mentioned, the Events section is only used for when something has been planned with a set date, time, and schedule of what's meant to be going on (cruise/meet/WTFBBQ or whatever).
Yep, got that. I'm just shit stirring now :P
P.s when am I seeing you next to give you this cargo net for your boat box?
https://www.sau.com.au/forums/topic/403435-eoi/page/2/#findComment-6416788
LOL, okay smarty pants.
Car should be back on the road this weekend - clutch replacement is booked for Friday - so I'll let you know then.
https://www.sau.com.au/forums/topic/403435-eoi/page/2/#findComment-6416901
