So I have an RB25 S2 with a GT3076r low mount at the moment. I’m looking at changing it to high mount setup. Was look to get some feedback on what exhaust housing size I should go eg: .73 or .82
Current setup made 18psi at 4000rpm making a max HP of 330 when it was first tune. Now the internal gate is giving me the shits and doesn’t make 18psi until 5500. I’m not wanting too much lag and will be happy if I get 18psi at 4000rpm once again on the high mount setup.
Supporting mods will be:
Greedy intake man
Front mount
Split fires
Power fc
3.5 inch exhaust
38mm external gate
I have looked through the Forms to try and find this information but no luck
https://www.sau.com.au/forums/topic/403526-rb25-gt3076r-turbine-housing-size/
  • Replies 57
.82
Smaller than that will restrict flow up top and with .82 on ext gate you should see full boost by 4000rpm
You should have made more than 330hp with a 3076r with a low mount though...
Edited by Mitcho_7
Be prepared to put in the money if you want to go a proper high mount setup with FFP, i was shocked when i realised how much my car cost to do.
Is saying that its a 3076/3037 and see's 21psi @ 3900 rpm easily and makes 485hp
You should be able to get a nice responsive 400hp in the low mount setup, there must be something wrong with the way you have it setup!
The tune was done at pits
The intake man was put on after the tune but had boost issues before that
First turbo setup was with an apexi AX53B70 made 292HP hit 18 psi at 3500rpm then droped back to 14psi at 8000rpm so when the GT3076r when on and made about 40hp more i thought i was doing ok
and yes 550cc injectiors fuel reg and fuel pump done with a Z32 AFM
Edited by gts-t 32
My last setup was just a high flow turbo, nothing special and it made 330-340hp at only 13psi so a 3076 can do better if its setup right, the turbo is a small piece of the puzzle :)
My highflow makes 240rwkw on a safe tune, so I definently think you should sort out what's holding things back at the moment before you go dropping $$$ on a high mount.
Who knows, you might end up being happy with the result, as is, when you get the issues sorted!
There is an issue with your current setup.
+1
And going to highmount wont magically fix it.
There is no reason an internal gate GT3076 on 18psi cannot make 260-270rwkw without issue. No-one else has problems with correctly sorted setups, so fix the current one before changing as the issue is clearly not turbo related.
You havent mentioned what rear housing you have at the moment.
I bet you have one of the following:
- 'skyline style' 6 bolt outlet for GT30s, by ATP or someone similar (bolts to the stock style dymp)
- Garret .63 5 bolt rear housing
Please clarify which one you have. If you have EITHER of those housings, that is your problem.
Change to a genuine garrett 5 bolt .82 rear housing and you will get the response AND get closer to 400whp.
That is low power even for the Apexi turbo, i have an ax53b70 and made 340hp on 16psi, 555cc, z32 and the usual other mods.
I think it might be sonic or something that makes those
Yes you guys are right, its a Sonic. The first week it was on it was great then I had to take it off and sent it back to sonic as the sleeve for the gate had come lose and wouldn't allow the internal gate to close. I still don’t think it is right and that’s why I want to get rid of it
The only other thing that could be letting it down is the monster performance intercooler brought of a mate a long time ago I’ve been meaning to upgrade it.
Yes I have tried preloading the wastegate more.
All other parts are good quality
Sard 550 injectors
Genuine greddy intake manifold
AVCR
nismo fuel pressure regulator
splitfire coil packs
z32 AMF with steel intake to turbo
Power FC
And a walbro fuel pump
Pits dyno is known for low HP readings but he is very good with Power FC
http://www.skylinesaustralia.com/forums/topic/127439-pitsmatty-spry-dyno/
    • f**king around with the bro
    • Ludenham   44.2 tops day no issues
    • Then today, I went to visit a man with an r33 hat Peter and Road and Race sorted the alignment. As it is being set up for general track/hillclimbs etc it has a heap of caster (7o), less camber than I am used to (1o front and 2o rear, as the caster looks after that in turns without the braking downsides), 3mm front toe out and 0 toe rear. Will see how that goes and track tyre wear to see if it does need more camber, but adjsustment is also limited with nismo arms and adjustable bushes at only 1 end. It does have a bent inner tie rod on the driver's side front but as it came up within spec I'll just leave that as is. So, that is getting close to my chapter of this story....could of tidy ups then a shakedown in early October before it finds a new home.
    • So, it went to Unigroup for a run in and tune on Friday, everything went (generally) well. In terms of fixes, the engine was good and there were no leaks. It needed plugs (I hadn't checked them because the coil pack cover was on a new engine and I couldn't imagine they weren't new.....but turns out the temporary plugs to just keep it sealed up were in there.....new plugs gapped to 0.8 and it was fine from there. Also, there was a little preload on the clutch slave which caused some slip. I haven't had the box off so I don't know what the clutch looks like; my guess it is brand new and the pedal had not been adjusted....backed that off a bit and it held fine. Last thing will have Dose crying....the idle especially when cold is a bit difficult between the cams, forward plenum, atmo blow off valve and an 80s air management system. It is fine when hot but a little uneven when cold, will see if I can sort or at least improve that one cold morning. Other than that, tuning went fine. It made 245 but was pulled back to 227 which 2 opportunities to improve in future. 1. The factory CAS is not great and was jumping around at high RPM, so Mark took 2 degrees out up top (that is why it stops making power and lost 20kw). Very safe this way and the extra power is available but will require a more modern ECU and better cam (or even better crank) sensor 2. The 2871 in factory housings is very big for a low mount, and the internal wastegate is too small, so it was creeping from mid range all the way to redline....the duty cycle on the boost controller is turned down a little for safety. That is much harder to fix, it would need a large external gate and that would require a whole bunch of other changes, so it will go as it is for now. It feels nice and healthy and safe, so should be good for about a billion laps like this.
    • what sort of caliper are they? If they are a slider and you gave everything a good clean, you might need to regrease the pins. My guess though is they will come good after some abuse as suggested above
