So I have an RB25 S2 with a GT3076r low mount at the moment. I’m looking at changing it to high mount setup. Was look to get some feedback on what exhaust housing size I should go eg: .73 or .82
Current setup made 18psi at 4000rpm making a max HP of 330 when it was first tune. Now the internal gate is giving me the shits and doesn’t make 18psi until 5500. I’m not wanting too much lag and will be happy if I get 18psi at 4000rpm once again on the high mount setup.
Supporting mods will be:
Greedy intake man
Front mount
Split fires
Power fc
3.5 inch exhaust
38mm external gate
I have looked through the Forms to try and find this information but no luck
https://www.sau.com.au/forums/topic/403526-rb25-gt3076r-turbine-housing-size/
  • Replies 57
.82
Smaller than that will restrict flow up top and with .82 on ext gate you should see full boost by 4000rpm
You should have made more than 330hp with a 3076r with a low mount though...
Edited by Mitcho_7
Be prepared to put in the money if you want to go a proper high mount setup with FFP, i was shocked when i realised how much my car cost to do.
Is saying that its a 3076/3037 and see's 21psi @ 3900 rpm easily and makes 485hp
You should be able to get a nice responsive 400hp in the low mount setup, there must be something wrong with the way you have it setup!
The tune was done at pits
The intake man was put on after the tune but had boost issues before that
First turbo setup was with an apexi AX53B70 made 292HP hit 18 psi at 3500rpm then droped back to 14psi at 8000rpm so when the GT3076r when on and made about 40hp more i thought i was doing ok
and yes 550cc injectiors fuel reg and fuel pump done with a Z32 AFM
Edited by gts-t 32
My last setup was just a high flow turbo, nothing special and it made 330-340hp at only 13psi so a 3076 can do better if its setup right, the turbo is a small piece of the puzzle :)
My highflow makes 240rwkw on a safe tune, so I definently think you should sort out what's holding things back at the moment before you go dropping $$$ on a high mount.
Who knows, you might end up being happy with the result, as is, when you get the issues sorted!
There is an issue with your current setup.
+1
And going to highmount wont magically fix it.
There is no reason an internal gate GT3076 on 18psi cannot make 260-270rwkw without issue. No-one else has problems with correctly sorted setups, so fix the current one before changing as the issue is clearly not turbo related.
You havent mentioned what rear housing you have at the moment.
I bet you have one of the following:
- 'skyline style' 6 bolt outlet for GT30s, by ATP or someone similar (bolts to the stock style dymp)
- Garret .63 5 bolt rear housing
Please clarify which one you have. If you have EITHER of those housings, that is your problem.
Change to a genuine garrett 5 bolt .82 rear housing and you will get the response AND get closer to 400whp.
That is low power even for the Apexi turbo, i have an ax53b70 and made 340hp on 16psi, 555cc, z32 and the usual other mods.
I think it might be sonic or something that makes those
Yes you guys are right, its a Sonic. The first week it was on it was great then I had to take it off and sent it back to sonic as the sleeve for the gate had come lose and wouldn't allow the internal gate to close. I still don’t think it is right and that’s why I want to get rid of it
The only other thing that could be letting it down is the monster performance intercooler brought of a mate a long time ago I’ve been meaning to upgrade it.
Yes I have tried preloading the wastegate more.
All other parts are good quality
Sard 550 injectors
Genuine greddy intake manifold
AVCR
nismo fuel pressure regulator
splitfire coil packs
z32 AMF with steel intake to turbo
Power FC
And a walbro fuel pump
Pits dyno is known for low HP readings but he is very good with Power FC
http://www.skylinesaustralia.com/forums/topic/127439-pitsmatty-spry-dyno/
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
