Hi im new to nissans and stageas so could someone help me id my stagea it has a dayz bodykit on it but im no too sure if it is an actual days edition it also has a couple of carbon fibre parts that im not sure if they are an aftermarket thing or a option.
model number
TGKNREAC34UDA
Also there is a number (if it helps or not)
GF-WGNC34
The carbon fibre parts are on the side mirrirs and one on the bottom lip of the front skirt and has a DAYZ neo edition sticker on it
Any help would be good
Cheers
DJ
https://www.sau.com.au/forums/topic/403540-stagea-id/
Can look it up tonight for you. Have you got any pictures ? i am guessing it is combo of Dayz and aftermarket. Mirrors will be aftermarket.
Do you have the Chassis number.. ( can't think of the format right now. maybe GF-WGNC34-XXXXX ) I can check in Nissan fast tonight.
Welcome to the Stagea family. Where are you located?
https://www.sau.com.au/forums/topic/403540-stagea-id/#findComment-6419025
Funnily enough I had just installed FAST today whilst at work... Searched your VIN but couldnt see anything optional. Hopefully somebody else can find it for you (and maybe explain to me where to see the optional stuff!!)
Adrian
Edited by adey88
https://www.sau.com.au/forums/topic/403540-stagea-id/#findComment-6419175
Adrian
Top toolbar, 2nd button from the right "OP" is options. 3rd button from right "MC" is the model code breakdown. I think I got that right lol, haven't used fast in a while.
https://www.sau.com.au/forums/topic/403540-stagea-id/#findComment-6419471
so no one found any info on this??
Sorry buddy doesnt look like it has any options. Maybe review the screenshot and confirm that the other details are correct (colour/year/transmission). The VIN number you gave me was 1 digit too long (the 0 at the end got dropped off).
https://www.sau.com.au/forums/topic/403540-stagea-id/#findComment-6420210
Man how did i miss that button? I must have clicked everything but that !! haha...Its a nice program, dont suppose you can read japanese and know what are the options on my car? I assume it has the cold pack and a LSD (crappy lsd as i can spin one wheel in RWD)...
https://www.sau.com.au/forums/topic/403540-stagea-id/#findComment-6420228
yeah i did about the same, took me a while of randomly clicking around to figure the ins and outs of the program. Most of the time you can make a pretty good guess at what options you have, so for yours i would say yes, an LSD. and the other one looks like your car may have been fitted with the 100v AC inverter.
https://www.sau.com.au/forums/topic/403540-stagea-id/#findComment-6420915
carbon mirror covers are a DAYZ option, most of the DAYZ parts werent fitted at the factory, so you'll have trouble finding the option codes for them.
what colour is it? pics?
these might help you out too
https://www.sau.com.au/forums/topic/403540-stagea-id/#findComment-6421055
    • Threads merged. Only need one for the same question.
    • Hi everyone, I'm about to complete my first single turbo conversion on my R32 GTR and I thought I would post the step by steps that I will be following. I will list the parts I have / the parts I will be buying. I will be redoing this guide after I have completed the conversion. Parts list: - 3576 turbo 0.82 v-band (coolant and oil)  - v-band top mount turbo manifold - 50mm wastegate - manifold copper gasket - titanium manifold stud kit - turbosmart 3 port boost solenoid - link can lambda kit (wideband) - link ECU - radium 12AN push in valve cover fittings (pair) - hi octane catch can - 3.5inch downpipe - screamer pipe - pipe from turbo to intercooler - intake pipe setup - power steering relocation kit - oil drain block off plate - coolant and oil lines Now onto the step by step guide (please add / correct me if there's anything I missed: 1. remove fluids, twin turbo pipes, pod filters and afm's 2. remove the factory coolant hardlines from the hot side. 3. remove heat shields  4. remove the downpipe 5. remove turbos and manifolds 6. remove factory manifold studs 7. clean whatever mess you have made 8. install power steering relocation kit 9. install new manifold studs 10. install new turbo manifold with gasket 11. install new wastegate with screamer pipe 12. install new turbo  13. install new coolant and oil lines  14. install rear oil drain block off plate 15. stop and appreciate that you now have a single turbo in your GTR 16. wipe away tears of joy and install downpipe 17. install the wideband sensor into downpipe 18.install pipe to connect turbo to intercooler 19 .remove stock boost solenoid  20. install new boost solenoid 21.  install intake setup 22. setup the rest of the can lambda kit with the ecu  23. refill fluids and hope for the best 24. ask forums for help with issues 25. fix issues 26. drive your single turbo swapped r32 GTR into the sunset. Doneeeeeeeeeee. Now I know this isn't detailed at all but I will be doing that when the conversion is done. I will be posting pics and any helpful details i can and ill make sure to fit in as much information as I can. If there's anything I should know before i do this PLEASE let me know. Stay tuned for what's next. Thanks...
    • I have wasted too much time on this, more than I am willing to admit. I hope someone can set the record straight for me.  I want to replace my Nismo (non GT pro, non GT) standard 2 way in my R33 GTST with a 1.5 way... Ideally I want to get an ATS 1.5 way Carbon LSD, but I don't want to reuse my 29 spline 5x1 axle stubs, and new 30 spline 5x1's are impossible to get a hold of ($$$), and I don't want to drop the cash on going to 6x1 stubs and axles ATM. Which leads me to the Nismo GT Pro 38420-RSS15-B5 or RSS20, as they come with new axle stubs meant for the diff, and is "Convertible" from a 2 way or 1.5 way to "Other ways", but that is where I am stuck as the documentation is a bit all over the place.  To sum up what I have found I believe the all the Nismo GT Pro PN's are convertible from 2 way, 1.5 way, and 1 way; but Nismo sells 2 skus (2 & 1.5) so people do not have to disassemble to convert it.  I found this thread on 350z but it left the question unanswered. https://my350z.com/forum/engine-and-drivetrain/620032-nismo-gt-pro-lsd-1-5-vs-2-way-and-torque.html  Essentially the way I think it all works out is like follows...  2 way  1 way  and 1.5 way would be the center pinion shaft in the 1 way block, but with the with the center flipped 180*. So the ramped side of the pinion would face the 1 way gate and act like a ramp.    I can only get my hands on the 2 way in the states, and I am not trying to get stuffed on tariffs by ordering from Japan or anywhere else. I want to confirm that if I get the 2 way I can convert it to the 1.5.
    • Hi everyone, I have purchased my first GTR and I want to do a single turbo conversion to it. I've been doing as much research as i can and there are a few things that I can find and need to know. I need to run a coolant feed, coolant return, oil feed and oil return for my turbo setup. Here's what I know so far: On the hot side of the rb26 there is coolant feed, oil feed and oil return. Coolant return will be going around the front of the engine to where the thermostat is located. I will need to block off the rear oil return port. I will be running a turbosmart boost solenoid so any of the factory boost stuff wont be needed. Now onto what I don't know: 1. What do I do with the coolant / vacuum hardlines that run around the back of the motor?. 2. What do I block off or loop or move or remove?. I will be running the OEM intake manifold. 3. Is there anything in particular I need to buy for the cold side of the rb26?. I already have the intercooler and pipes sorted. If you have any pictures or information it would be appreciated. Thanks....
    • The fab work can be as simple as a couple of silicon hoses and clamps to the factory piping.
