This is a set of Racing Sparco Viper R Forged/Spun wheels which are almost impossible to find especially with the centre cover, these weight in at 8.1 kgs per wheel (give or take) one of the lightest wheels ever made (Made by TANEISHA Japan).
18x10 +14
GOODYEAR EAGLE F1 ASYMMETRIC tyres 265/35R18 on the indicators as seen in the picture above. The wheels need a good clean/polish, one of the wheels looks have little dents on the lip only this is caused by rocks as I've been informed by a wheels shop. Once cleaned and polished it will be gone and look mint.
NO GUTTER MARKS, NO BUCKLES, NO FLAT SPOTS ON TYRES.
Made and only ever sold in JAPAN (discontinued)
$3200 ono Contact : 0410120884
Edited by tokyoparts
Swear to god those are the same rims that were on the Autostyle baby blue R34 GTR, hot looking rims to say the least and something a little different.. Free bump
  • 3 weeks later...
  • 1 month later...
18x10 +14
$3000 ono Contact : 0410120884
  • 3 years later...
    • Ok so after much research and talking with knowledgeable people I've got my turbo conversion done and it's all running great other than 1 small issue.  Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd. But nothing drive or what gear your in when you pop it into tiptronic.  I'm sure there is may e 1 wire in the ecu plug I need to move to rectify this. Dose anyone here have any ideas?   Cheers guys
    • Sorry I haven't been following all the detail, so you may have tried this. Does it idle with the tiniest bit of throttle you can add? You've mentioned the IACV, does it have an AAC valve and have you adjusted it at all (ie, screw the idle adjust screw all the way in, then back it out a couple of turns until idle is stable)?
    • My bad, I unplugged the one underlined in red instead of yellow before. With the car started, after unplugging the IACV (the one underlined in yellow), it idled at around 400/500 for 3 seconds before stalling. Attempting to start the car without the IACV will not start the car.   It does stutter and sputter for around 5 seconds before dying. However, immediately after starting it, you can already hear some slight sputters from the exhaust.   It won't start with the AFM unplugged. If it is when the car has already started, it stalls in a few seconds.   Yesterday, I did take some logs using Nistune of 3 scenarios. Car idling till it stalls Car idling and unplugging the IACV Car idling and removing the AFM I also have some previous logs of when the Car is idling till it stalls and when driving and it cuts. I am not really knowledgeable enough to understand what to look for. After every test, car idles rougher and rougher, until I have to stop. It will be fine the day after.
    • There is no difference between a 17x8 and an 18x8. The total diameter of the tyre needs to remain +/- the same (so you don't mess up the gearing, speedo reading, and clearance when turning front wheels..... so you just need to use a lower profile tyre on th 18 than you do on the 17. /rocket surgery.
    • I thought the same to start with. But then I thought it was one of those LCAs where the end of the ARB goes through a bushing in the LCA itself, instead of having an end link.
