hi im doin a RB 25/30 specs include :
spool RB30DET (DOHC) Rebuild Kit CP 9:1 , RB head oil drain kit, Camtech 268/272 cams , RB25det head , RB20 covers, oil pump spool, crank collar, turbo manifold 6booost,
RB26dett plenum, HTA GT3586R turbo , water pump N1, R34 RB25det 5 speed gearbox
some pics :
RB30 as i got it
RB25det head as i got it
RB25det head sittin on the RB30 block with the RB20 covers and with a modiffied KKK turbo just for looks!
will add more pics as i go
CHEERS Oscar
Edited by MRHD66
https://www.sau.com.au/forums/topic/403700-my-rb2530-build/
  • Replies 43
Posted Images
How is the rb26 plenum going onto the rb25 head? Pretty sure they aren't compatible without a shite tonne of modifications.
Also, you should have put this in the build section!
power tune do a manifold adapter kit that I will be using
https://www.sau.com.au/forums/topic/403700-my-rb2530-build/#findComment-6423063
how so mate
The water galleries are offset from one another so the plates need to mismatch to create an angle. You cannot use a gasket in between the two halves as it will block the outer one
They may be ok but from personal experience they are a complete f**k around to seal properly. Most people just use a tonne of silicon but that can block the water gallery and present its own problems
They may have changed the design since I saw the last one though so put up some pics once you get it
https://www.sau.com.au/forums/topic/403700-my-rb2530-build/#findComment-6423240
how much f#cking around Is gettin VCT to work on a RB26 head
For me.....none at all.
I'm not suggesting you go RB26 head but there are no gains by going RB26 plenum and throttles. In fact, your tuner is going to have an extremely hard time making it run nicely. You have essentially lengthened the intake runner by another inch or more which creates all kinds of problems with air bouncing back from the valve head and transient throttle at lower revs.
You are definitely better off with a Greddy or similar.
https://www.sau.com.au/forums/topic/403700-my-rb2530-build/#findComment-6423271
how much it cost to make RB26vct and do u use a RB25neo intake cam? I know it's not just cam too Edited by MRHD66
https://www.sau.com.au/forums/topic/403700-my-rb2530-build/#findComment-6423277
It's about $2500 with the head off.
No we designed our own custom camshafts. It's also important to consider valve clearance so not something I would recommend attempting at home
https://www.sau.com.au/forums/topic/403700-my-rb2530-build/#findComment-6423279
yeh mate I will get all that done when I get the VCT oil feed welded up
https://www.sau.com.au/forums/topic/403700-my-rb2530-build/#findComment-6423368
    • Hi all,  I am in the market for an R200 longnose diff out of a Z31 300ZX, or S12 RSX, DR30 skyline, or similar, in a 3.9 ratio.  Preferably a late model one with the M12 crownwheel bolts.  The only easy to find advert for one of these was my ad back in 2007 when I sold it on this forum.  I sold the diff as I had sold the car it goes to, but as it turns out, after 18 years I got the car back late last year, so now I'm looking for the diff !  If anyone knows where to find a longnose R200 LSD with the M12 crownwheel bolts, drop me a line at [email protected] - Bonus paid if soomeone comes up with the original diff (stranger things have happened !).  Cheers   Ben D
    • Hi everyone, I used to post here a bit from 2004-2013, when I owned various Nissans, in particular my S12 RSX gazelle, which was sold in 2007.  As luck would have it, after an 18 year hiatus, the car found its way back to me last year, and over the past 11 months I have had the pleasure of restoring it with my kids.  One thing that I am after in particular is a 3.9 ratio R200 LSD for it.  I actually sold the one out of the car here back in 2007 , and it would be incredible if I could track down who I sold it to, so I can see how they have progressed over the years (and to be honest, to see whether I can get the diff back !).  Anyways, hi all and let me know "where are the R200 Longnose diffs all at these days ?  Cheers Ben D
    • Arms will be the same as the G35 or 350Z, but as above, there was a change in the lower control arm where it connects to the ball joint.  That said, you can remove the ball joint cone from your old ball joints and fit them to the new ball joints.  To be honest, I didn't think the ball joints themselves were different. The main ball joint is a bit awkward to replace, you really need to remove the steering knuckle to press out the old one.  Some people have used tools to remove it in place, but it just seemed too hard to get to. If you are going to press out/in that ball joint, then you may as well just replace the bushings in the LCA and the compression rod.  You can buy the compression rod bushing from Nissan, but the LCA bushes, you will need to go aftermarket. Much cheaper than buying the whole arm.
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
