Hi guys - was searching through alot of posts for the past few hours, this problem started happening around a week ago and has gotten worse since.
Symptoms:
Car doesn't start first time around
If I push on the throttle even slightly, it feels like the fuel supply has cut off ... ONLY happens under load not while stationary
Car turns off from time to time at traffic lights etc
Drives sluggish but ok at a steady speed, i.e. if I'm going on the freeway at 100 or on a street at 60 while keeping the throttle stationary.
Things I've changed:
Spark plugs, properly gapped
Cleaned AFM
Inspected coil packs (yellow jackets with less than 1000 km on them)
Cleaned most contacts with contact cleaners
Changed fuel filter
The fuel pump sounds like its priming, the old fuel pump was replaced with a new walbro unit less than 1000 km ago from dr drift, could that still be a culprit? From what i've explained, does this sound like a fuel issue or could be something else?
The only other thing i've noticed is a light on the HUD coming on alot more than it used to, here's the pic ... http://i45.tinypic.com/2m7axap.jpg ... I was told last time that this means a collapsed CAT? Would a collapsed CAT cause these symptoms? I put in a used (good quality) CAT around 2000 km's ago.
I'll take it to a mechanic as soon as I can but thought i'd check here for some friendly advice =)
Thanks guys!
Edited by agentx
https://www.sau.com.au/forums/topic/403824-fuel-cutting-off-or-something-else/
Checked the above, no apparant leaks etc after a thorough inspection - and CAS is tight. Took AFM off and did the dry solder fix, the car is now hesitating for a few seconds initially under load but once i back off the throttle and ease into it again, it goes fine =/ if it was the AFM, it wouldn't be fine after that would it? Goes fine even till 7k rpm after that and pulls fine..
The EGT light is coming on alot now, next step will be the ECU diagnostic unless anyone else has any other suggestions?
I would have done a diagnostic check before i started re-soldering afm's etc. I would pressure test for leaks, if thats all good I would start looking at your fuel system. 1000km old fuel pump... Started doing in the last week... Id be checking that out.
Edited by GoHard
Just finished a diagnostic - it was 55 (all clear) but surprising find ... when i took the ECU out, the light wasn't actually on till I played around with the adjustment screw! In the r32 (Type M), the EGT acts as the check engine light (confirmed now) so when I turned the ignition on, that EGT light wasn't actually turning on (and obviously the LED wasn't either)...
What could that mean? Anyway i adjusted the screw after the diagnostic and made sure it (as well as the EGT) was in a constant ON position before i put the ECU back in.
Did a ecu reset (by disconnecting battery) and went for a spin and now its a bit better but still definately hesitating on certain RPMs across the range, its more like a flat spot now but once it takes off ... it takes off. Next is to test fuel pressure and then AFM.
Its so frustrating, I've called numerous workshops and asked that i JUST want to check fuel pressure but none of them want to do it, they all say drop the car off and leave it and we'll diagnose the issue etc etc. I don't want that, ALL i want is to check fuel pressure dammit! might buy a gauge and do it myself lol
  • 3 weeks later...
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
