Hey guys, random question, when I'm filling up and I put the bowser nosel all the way in and pull the trigger, the fuel must be getting restricted in the tank and splashing back causing the bowser to click and stop. When filling up I have to shoot the petrol into my tank (literally hold the nosel 5cm away from the hole) and only hold the trigger half way otherwise it'll spill out. Never had this issue in my old R34, and it takes 10-15mins to fill the car up. Any ideas what could be causing this? The car has an aftermarket fuel pump unsure whether its internal or external, although something is restricting the fuel tank opening.... any ideas?
https://www.sau.com.au/forums/topic/403842-filling-up/
LOL. ive had this pain in the arse on many cars, I dont know about keeping it 5cm away and shooting it in, Most would end up on you and the paint work.
Just nugde it in a little, Or sepnd a min or two finding the sweet spot. I find that all the way in dsoent work on many cars and as you said just keeps clicking.
Fuel pump has nothing to do with it either mate, its the fuel tank itself.
I think the angle of the boswer handle has alot to do with it.
https://www.sau.com.au/forums/topic/403842-filling-up/#findComment-6425932
bingo-same with me.
Nozzle in about an inch find the right angle n she will take it full steam.
these are japanese cars after all :whistling:
Edited by jjman
https://www.sau.com.au/forums/topic/403842-filling-up/#findComment-6425955
LOL! Thanks for the laugh at work guys...this question now means that every single question I ever had in my mind about my R33 has been asked and answered on this forum. You guys are the best!! I love this place! :yes:
- Yup, I also have to find the sweet spot on my R33 to let it flow.
Edited by dex_911
https://www.sau.com.au/forums/topic/403842-filling-up/#findComment-6430091
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
    • Hi @Chupapy i had several leaks from coolant pipes being corroded, i also had one leak on back of the head onto transmission. For me that leak was from the turbo water line. Follow the line to the back of the head The hose and metal pipe had perished these are the best pics I took of it at the time
