This is a well looked after vehicle which has all the usual modifications.
Car has BC coilovers (height and ride adjustment) near new < 5000km
Garrett GT30/40 Turbo
GReddy Front Mount Intercooler
Walbro 600hp fuel pump + Sard rising rate regulator 1
8x8 18x9 ROH Drift R wheels with very good tread (brand new front tyres)
Blitz Fibreglass ADR Compliant Bonnet
3.5" Exhaust
Car is fully engineered in NSW This car runs very well has always been looked after, regularly serviced using quality parts. Although has a few more Ks then other vehicles these are 90% highway Ks.
Car has DYNO readings for 247rwkw (12 psi) I welcome a good test drive and can arrange a mechanical inspection if required.
Reason for Sale: Have purchased new Navara. This is a very regretful sale but car must be sold. Will be happy to sell to someone who can look after her.
Price $13 999
Contact Ryan 0408705412
I am very rarely on forums anymore due to work and personal commitments, please contact via my mobile number.
https://www.sau.com.au/forums/topic/404042-fs-r34-25gt-t-coupe/
  • 3 weeks later...
Hi Guys,
I have had a fair bit of interest with the car but have been busy moving house and with work. If you want more detailed pics of the car or any further info, please either call me or text me with your email to send them to.
Also have lowered Price to $13499
Edited by OG.R34
    • Power steering is probably because someone has nuked the HICAS CU and you no longer have the variable power asist doing what it is supposed to. How much boost are you running? You are aware that any more than 10 psi on the stock ECU is just asking for it to go to full R&R (that's Rich & Retard, which is effectively Retarded and Retarded!) which kills all the power. Depending on the exact conditions, it can just be runnign on the fat and stupid end of the maps, then the conditions change, you make a little more boost and the ECU goes into panic.
    • @BuiltNotBought Just as GTSboy said.   If you want driveabilty and more low down torque..keep the stock runners. They are VERY good from a factory. I have them too on my RB25DET NEO and as a GTSboy i have fmic but with stock piping route(i have Blitz intercooler) Iam making around 320 BHP and the car pulls "hard" from like 2,5k all the way to 7k. I have it dyno tuned to mimic N/A power curve and making little less max torque due to the smallbox tranny. But driveability is very great. I had 350Nm below 3k so car feels very quick.
    • Looking to sort out a couple of issues on my skyline  It recently was rebuilt, however rebuilder long story short did not give two flying effs about the work he did. So moving forward it's running but I have two persistent issues 1) it has a misfire / lag type of issue (was at higher RPMs but I had a dead piggy back ecu removed which improved it) now it's not as bad but still does it at random, I thought it may have been a boost issue I'm running an older turbosmart dual stage controller, turbosmart told me to try running off gate pressure however it still has a lag at random times. It has New MAF, maf plug, coil packs, sparks, CP harness.. injectors tested and cleaned. Factory ECU. 2) Power steering issue. It is tight as anything. Flushed power steering, rebuilt my pump because the bearing was shot. Flushed again still tight (mainly when parking and going slow into my driveway etc)  No kinks in hard lines, replaced the lines I could see had cracks. Still tough to steer.  I was told to shim a coin and place into the solenoid plug? Is there anything else. My steering angle sensor also has a issue. It's a used one I replaced, does it need to be calibrated? I feel like I've tried everything and this car is my voodoo doll.
    • Holy shit... wow!!! I totally missed this
    • One main filter. Each tank has a prefilter to keep rocks and small children out, then the big main filter that also does water separation. Clogged the first one so bad it was like a rev limiter at 3200rpm. Literally just like dropping the throttle off and maintaining rpm!
