R34 Gtt Neo Engine Turbo Id Has Garett A/r .60 M24 N1 On Com Houseing And No Id Plate Has Ceremic Wheel Comp And Exhaust.
ok i know there has been lots of people on here asking to id their turbo's and i'm new to this so bear with me.
On the com houseing it say
GARETT A/R .60 N 1
on a raised section inbetween the N and the 1 it says oy2a or could be OY24
there is no id plate on the turbo as this would make it easy.
i do know it is a ball bearing turbo as it has the 10mm nut/ bolt in the centre between the comp houseing and exhaust houseing.
On the back side of the exhaust houseing it has cast into it c op6
The waste gate has part number ASN82 33 in large painted numbers/stamp then under that has 1221A
I have also notised that on the back of the comp houseing is marked 1D416 maked on with a pen/paint
Any help would be great
Thanks Dave
that tells me alot.
I want to know if it is a t25 t28 gt30 or what the hell it is
If it is a n1 turbo.
what is the max boost it can cope with and how long they last for?
It's a standard r34 gtT turbo. It can run infinity boost. And the best thing is its legal! Yayayay
Now don't be a tart and accept that it's stock.
Inbeforetailor
Stock neo turbo.
It will be good for about 200 - 210rwkw give or take 10kw.
Max boost is limited by your imagination but history shows that it will live a longer life if you stick to 10-12psi and won't make much more (or any more power) if you lean on it harder but you will end up with turbine in the cat disease sooner rather than later.
It is also in your interests to spend some time searching on SAU. Any question you can think of has been asked and answered many times before particularly when it comes to stock turbos.
i thought the neo op6 was a hitachi like the other stock RB25 turbos?
since when does a neo run a garrett?
Yeah but what boost level?
All RB ball bearing turbos are Garrett
LOL
Ok from what you have all said it's just a std turbo, thats fine and will only handle max 12psi thats fine too, as i have the engine in a lc gtr torana. i took it to willowbank and shit the clutch and roll through for a 13.6 @101 so i know the car has a lot more in it as i stuffed the start and killed the clutch and was only running 8psi.
Current mods to engine are s1 pom cams std ecu 3" turbo back exhaust 100cel cat and free flow exhaust split fire coil packs and a 600x300x76 intercooler. soon to recive new clutch from extreme clutch part # kni25003-1r
From what i can make out the engine is out of a s3 as it had the red writing on the engine cover and the turbo has a metal twin blade comp wheel.
Dose anyone know who is the best to talk to about hi-flowing the turbo and fitting steel exhaust wheel.
Cool, I had an LC Torana as a paddock basher when I was 16.
There is plenty of usable power to be gained in an aftermarket ecu...PowerFC, Vipec/Link, Haltech etc.
Aftermarket turbos has lots of threads here in Forced Induction with the most commonly spoken about being Hypergear but there are a huge number of options so name a target power figure and that will narrow it down. Click the search button and read.
Lol very funny old timer, I missed that one when I looked myself. I did actually check first as I didnt want to make a dick of myself. Want not want whatever dick made, hooray lol.
thanks tho, its something I wanted to know :P
lol
    • Time to decide what’s more import, your power level or your budget because you’re going to struggle to keep both
    • Our Southern Highlands Cruise is proudly registered with “R U OK?” Day.  Sometimes the best way to check in on your mates is by getting out for a drive together. Sharing a common passion like cars creates the perfect space to chat, connect, and support each other.  A simple “R U OK?” can make all the difference. Let's enjoy the drive, the company, and look out for one another. PLEASE WEAR YELLOW FOR “R U OK?” DAY Sunday 14th September 2025 9:30AM Meeting Crossroads Homemaker Centre 10:00AM Cruise Departure Via Old Hume Hwy 11:45AM Arrival at Mittagong RSL Club Meet Location: Crossroads Homemaker Centre Final Destination: Mittagong RSL Club *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • Yep, its been down for a while, as I understand it it will be back soon.
    • Yeah I also looked at Plazmaman, but, it ended up alot  cheaper getting black ones through EFI when you also added in the delivery cost
    • Nice shot! They look super clean. The roof rack delete on the black one is interesting. Would like to see more pictures from different angles. It's subtle but could make quite a difference to how the car looks in profile.
