Hey All,
My S2 Stagea has a problem with it's Xanavi head unit. It seems to power up and beep, i can control the temp and the radio works, but the screen is totally blank. I have had the car for about a month and one random day the screen turned on and everything worked perfectly (all be it in Japanese) but then when i turned off the car the screen went blank and it hasn't turned on since.
So it seems like the screen works fine, but there is a power connection or something somewhere.
Does anybody have ANY idea how to solve this? Is it a common problem? Is there anybody I can sent it to and get it fixed (i'm in the UK but happy to ship to Aus)
It's such a bummer as the aircon etc all operate through this so i can't just remove it.
DOH!
Any help, much appreciated!
Cheers
Chris
Hey Guishnu
I can only suggest to remove the entire unit and look in the back. There's quite a few plugs, maybe one has become dislogded and it's not recieving an ignition or power signal. I removed mine recently and noticed there's a fan at the back, which i assume is to keep the display cool as it heats up. It might be that at some point your display has overheated. Keep in mind these units can be 12yo or more.
Good luck and keep us posted if you solve it
Cheers
Hi, just got a s2 stagea with the xanavi headunit too. When i went on the freeway (100km/h) i noticed my screen turned blank and stayed blank after a few min. I could use the aircon, turn on/off and and the other button on the climate light up. 2 min after slowing down from 100km/h the screen came back as normal. Not sure if this is of any relevance to your fault but it may be something to check, somehow.
Totally randomly, it has started working today. May be something to do with the weather getting hot here in the UK. I'm wondering if it's some damp or moisture in the system somewhere?
Weird.
Now from past experience with my old R32 with the aircon controls and other electronics. Nissan's PCBs are prone to what its called "dry solder" issues(when solders become loose with the components due to age). What I ended up doing is re-heating the old solder to make it stick to the components again. Not sure if this would help but surely
Nissan would have improved their soldering techniques by now!
Yeah, there is a problem with it somewhere. Sometimes it works, sometimes it don't :-(
It actually only seems to work when it's hot outside...
Anybody selling a second hand one?
    • Hi, i’m making a rb25det coil loom for Vag short coil. Can anybody tell me which Ecu signal wire belong to coil number 1 and 2,3,4,5,6? The connecting switch in above pic is 8 wire i think white is for +12v and black for earth.
    • Was there ever a model of the Stagea m35 that didnt have a badge on the grill? I thought I saw that somewhere, some aero edition or something? I cant find it again? davemoto
    • Its a 2002 vr-x four VQ25DET, silver. Coil overs, lowered, polished alloys and sport exhaust. Bit of a project, was sitting in a shed for a while but runs and drives great.
    • I wasn’t able to replicate the sound anymore. It was a one time sound so maybe it was just coincidence but it was like small pebbles being dropped in a coke can.   should I try cleaning the MAF? It could be it’s functioning but dirty? I don’t know.
    • Update 4: Hi all. The car drives again! Haven't driven for long, only to store it in the garage again, but the test drive was successful. The coolant and oil leaks seem to be fixed for now. Temps on the engine were also very good, while moving I never even saw 80C water during the approx. 30 minute drive. Ate up all the coolant in the reservoir though so will have to fill that even more when I go to the car next time. One thing that pisses me off is that the RPM gauge is still f**ked, I even resoldered the board twice and used copper paste on the silly screws that are used as connections. Next time I take it out I'll take apart the board and fit new components, I'll see if I can get a replacement IC for it.  I have an appointment set for 22nd of September for the engine tune to 370hp. Alignment also still needs to be done. My hope is that I can get all the legal stuff over with by the end of this season. Anyone of you have advice regarding intercoolers? Currently there is an APEXI core fitted, one of those weird hybrid ones, 600x270x76. I don't think it's bad but it's not new and now I still have the chance to change it now to legally include it in the paperwork. Only issue is that the only options that would arrive in time are a HKS Type R intercooler or generic Ebay spec intercoolers comparable to a JustJap one. Ideally I'd order a Plazmaman but it takes over a month to receive which would mean making the car legal has to wait until next season. Would love to hear some input on this. Same story for my injectors, the previous owner was a nunce and put ID 1050x on the engine. They work but are obviously not ideal at "normal" power levels. But I don't see a reason to change them unless the tuner says it's necessary. I read online before buying a different exhaust that the top secret style rear diffusers won't fit due to the size of the rear resonators. My buddy and I made it work by slightly "adjusting the shape" of the mounting bracket and making some spacers out of 3d print for the mounting bolts. Fits like a charm. Just putting this here in case someone has this problem. Even the hefty HKS Silent Hi Power rear can fits without hitting anything.
