  • 6 months later...
Buy them from Crows Nest Nissan - I would go for the genuine part over any aftermarket cheaper alternatives.
I have a horrible feeling my wallet is going to suddenly be a lot lighter :D Does anyone have a cheap source in Japan (for Nissan originals)?
Lucien.
I have a horrible feeling my wallet is going to suddenly be a lot lighter :cheers:  Does anyone have a cheap source in Japan (for Nissan originals)?
Lucien.
you might be surprised, i have found that often genuine parts are pretty reasonably priced.
but then again, sometimes they are not.....
did u end up getting a price yet?
PM me when you do...
No, unfortunately. Between organising a groupbuy of PFCs, life in general, and then my dog needing emergency surgery, window seals took a back seat. I will try to get around to it tomorrow and let you know.
Lucien.
Hi Guys,
I finally got a chance to check some pricing. Here goes:
Front Windscreen Outer Moulding (Kit):
Part Code: 72810
Part Number: 72750-04U10 or 72750-04U60 (one is superceeded):
Price: ~$175 (SAU NSW Club Members ONLY)
Rear Windscreen Outer Moulding (Kit):
Part Code: 79810
Part Number: 79750-04U10:
Price: ~$461 (SAU NSW Club Members ONLY)
Door Seal (Driver's Side; on chassis not door):
Part Code: 76921R
Part Number: 76921-04U00:
Price: ~$41 (SAU NSW Club Members ONLY)
I am waiting for Troy @ Crows Nest Nissan to confirm availability and the prices listed. He has been very helpful, so big thumbs up for him.
I must say the front windscreen moulding and door seal seem very reasonable (well, considering its through Nissan Aus), but that rear windscreen moulding seems ridiculously expensive: is Nissan making them out of gold or something? :)
A few other notes: I imagine the price for a passanger side seal is the same, though I didn't check. To be clear, this is the seal that sits on the chassis, and runs around where the door and window meet the chassis, as opposed to the seal that sits on the door.
Hope that's of some help to people.
Lucien.
I have no idea what the driver / passenger chassis seal thingy would be...
What do you mean? There is a seal that runs around the inside of the door area on the chassis: up the B-pillar, across the top, then down the a-pillar. Its 76921R in the diagram.
if it's the rubber thingy which usually has cracks from the doors then count me in for a new set
Its this I believe:
Its a standard price for an SAU NSW Club member, such just give Troy a buzz. Alternatively, wait a few days till I get mine and I can say if its the same thing as in the above pic :D
LW.
lol $55 to join the club, start saving on parts :(http://www.skylinesaustralia.com/forums/sh...ead.php?t=44115
Exactly: pays for itself.
Only problem is that its not exactly obvious how to join the club: I have already had two people ask me in a day. Could PranK modify the front webpage with some links to information about joining the various state clubs?
I got a call from Troy saying my driver's side window seal and GT-R key are already in. How's that for service: less than 24 hours!
LW.
    • Guys since i bought r33 gts25t coupe 1994 automatic a/t(manual swap 350z gearbox)  all i got is problems, always problems. Lets start with that when i turn key into ignition(ON) fuel pump doesnt always works. Sometimes i have to turn key twice Off/on/off/on until it primes. Its new, dw300 - 340lph. My gearbox broke so i did gearbox swap, install different intake manifold, injectors and i take pipes. Car was sitting in garage for more than half a year. I did assembly all not that long ago and when i turn ignition cant hear prime. All of sudden it stopped working. Theres many videos on YouTube how to make relay mod on r33 straight from battery so i did and it doesnt work! 😰 30 - battery positive  87 - positive from fuel pump to relay 85, 86 - one of two wires from original fuel pump wires(light blue, grey) and it didn’t work. so I check on ignition and took original BLUE relays wires from trunk, next to fuses. (I believe it’s IGN+ and ECU pin 18. it didn’t work…  tried connecting (IGN+ from og relay) and (ECU 104 from 1of4 FPCM wires) to my new relay 85/86 and it didn’t work.  I unplug FPCM. Didn’t work. im thinking what’s wrong   fuel pump is working, if I leave IGN+ on 85 and 86 straight to ground it works but it’s just nonstop. Since it getting constant 12v after key in ON. light blue wire gives me 6-8v.  so how this should be connected? What causing ECU not giving — on pin? Or I did sth wrong and that’s why it doesn’t work? I need negative signal on ECU that control fuel pump. What this should be?
    • You can use your VIN to look up the factory part number somewhere like amayama, and then look to order new if necessary. https://www.amayama.com/en/genuine-catalogs/nissan Depending on price you might want to rebuild instead. @GTSBoy I had an interesting insight into US market parts when the Titan rear calipers were sticking. New calipers were dirt cheap, about 20% more than a rebuild kit....they are just considered throw away maintenance items
    • Funny, but really not funny. Thank god (most) f the world has moved on since then
    • Lots of votes for driving onto a plank first; that is the quickest way I've found, 25mm is enough for my case but that will vary by car It also depends where you are going for. On the 32 I can get to the rear diff with my floor jack if I do that end first, and get it up on stands. Then I lift the front from either front tow hook as high as needed, also onto stands. Sometimes I need a small lift on the other tow hook to get it level enough If I do the front first I can't get to the rear diff because of the angle of the car Other options are getting to the front mount of the rear subframe from in front of the wheel (if only lifting one side, or just do both which is a bit of a pain compared to one lift from the diff), or also the gearbox cross member mount on the driver's side if you are  just trying to lift the driver's side. I This is the jack I use; it says 75mm clearance but of course that is only on the lower section so if you have to reach too far in like the diff you still get stuck. https://www.snapon-bluepoint.com.sg/category/Floor-Jacks/product/Floor-Jack,-2-Ton-Low-Profile
    • On the bright side, the weather will turn much nicer for working outside shortly....sounds like you might need to start on a neighbour's garden next
