Oh its my turn to shite shir haha Been a while
Your ghey turbo timer is a adr defect ( but I'm sure you dont care!) but it must time how long you wank off ...so the 30 seconds is enough to cool off ? or set for 1 min so the oil has time to cool off and not stick to your palms
But its good to know your master mind fixed it " gold star to you "
In the future ask questions with some respect to the ones trying to help you ffs or expect a ban stick off SAU
A lot of people on SAU have skills well beyond what you could even imagine and help people in need if asked polite !! instead they could say FU pay someone to fix it !!
So chill out
Even if you dont agree show some respect for your fellow sau members
End rant , waits for bitchfest so the ban stick can come out
The question is a nissan is a soft target ( crime in japan isnt rampant like here) multi layered approach to security and even a 10 buck club will slow them down and stop joy riders
Gps tracker is a must on any decent cars and even that isnt a magic fix
Common sense is one major prevention of theft
Exactly i couldn agree more show respect were respect is due. post count doesnt represent ones knowledge, stupid questions get stupid answers and stupid answers get snide remarks and this is all defined by the individual users intepretation, so go figure. Welcome to the internet my friend :-)
Thank you for listening , come again
Off topic
(Been on the net before it was called " the net " or before it was pc based ) and remember punch card mainframes at college lol
But the lack of respect and keyboard warriors flaming is from the past 10 years more so the last 5
Taking the piss is not the same as disrespect
Anyway its cool
*Thread hijack
So would this mean that my security is compromised since my turbo timer (which I actually use as a boost gauge) is still in the car, Chris?
Or was there something done to the wiring to make it that much harder to steal?
troy ,
lol :)
either of your will take a truck (or me) to move them.
  • 1 year later...
Now in all seriousness, I just brought a hks turbo timer with a plug and play harness. I though this would be very simple. I plugged it all in. And done the ground wire. All the modes and stuff come up and it seems fine. But when I turn the car off it does not count down and leave my car running for the time displayed. My car will run for 1 second after I turn it off. I have a mongoose alarm installed. It immobilised it self after 30 seconds of turning the car off. I'm still new to all of this. Can anyone tell me if I'm doing something wrong.
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
