SUMMONER!!!!
Cam here how ya doin man.
i got my RSM from Car Quest, $400 for RSM plus $80 for G-Sensor, i put it in myself, pretty easy, except the manual was in japanese, so had to go online and get english version, i didnt see any commodore wiring diagrams in there though??
anyway come and have a look and see what it does next time ya see me if ya want, i rekon the RSM beats the hell out of G-Tech anyday, looks heaps better and does more and only a little more expensive.
Cya round.:)
https://www.sau.com.au/forums/topic/4045-apexi-rsm/page/2/#findComment-65555
yeah there pretty good, dunno how accurate they are but they are supposed to be accurate to within 0.01 of a second but ive never been down the quarter so i dont know, the h/p reading was pretty accurate though, that was spot on to what the dyno read on my last car.
https://www.sau.com.au/forums/topic/4045-apexi-rsm/page/2/#findComment-65564
i have the older style RSM, the one before the blue screen but its basically the same.
I set it down on the quarter and on a few runs it was spot on, and the rest were only 0.1-0.2 seconds off the mark. It all depends on wheels spin as it reads it from the distance travelled.
So in theory you could do a 400m quarter on the spot :)
Shaun
https://www.sau.com.au/forums/topic/4045-apexi-rsm/page/2/#findComment-65604
Originally posted by HJB
RadiuM,
I have the older style RSM in my R32 as well (When its arrives, should be a week or two). Once it arrives do you think we can catch up at one of the events and you could run me through the RSM functions?
yep, no problem.
its quite simple, i just played around with it a bit until i figured it out.
R33_cam, nope.. don't think the older one came with a G sensor (checks manual) but the new one might compensate for this.
We installed a new one in a mates car, I love the G sensor graphs, just like the R34 GTR. hehe :)
Shaun
https://www.sau.com.au/forums/topic/4045-apexi-rsm/page/2/#findComment-65838
:lol: yeah i think alot of the features are there to just look good :lol:
hks-s14::
they are pretty accurate with distances i rekon, measures to 0.01km (i think, don't quote me on that), its all resetable whenever you want, and can record your best times etc etc
now all i need is the SAFC sitting next to it, that would look sweet and mite actually make it go a bit better too....:)
https://www.sau.com.au/forums/topic/4045-apexi-rsm/page/2/#findComment-65874
  • 8 months later...
Just thought id let u guys know that Skylines Australia does not condone any of the silly behaviour as described in this thread. If you break the posted speed limit you run the risk of killing yourself and others and we all know nobody wants that. We have already had a couple of incidents in the fold over the last week or 2 so lets not go testing our RSM's to see if we can beat the land speed record eh?
If you really feel complled to give it a good test, Moroplex is open most weeknights for a small fee and its alot safer and legal there than it is on public roads. :D
Oh, no more references to illegal activites please. Any more and the thread will have to closed.:uh-huh:
https://www.sau.com.au/forums/topic/4045-apexi-rsm/page/2/#findComment-353325
    • I came here to note that is a zener diode too base on the info there. Based on that, I'd also be suspicious that replacing it, and it's likely to do the same. A lot of use cases will see it used as either voltage protection, or to create a cheap but relatively stable fixed voltage supply. That would mean it has seen more voltage than it should, and has gone into voltage melt down. If there is something else in the circuit dumping out higher than it should voltages, that needs to be found too. It's quite likely they're trying to use the Zener to limit the voltage that is hitting through to the transistor beside it, so what ever goes to the zener is likely a signal, and they're using the transistor in that circuit to amplify it. Especially as it seems they've also got a capacitor across the zener. Looks like there is meant to be something "noisy" to that zener, and what ever it was, had a melt down. Looking at that picture, it also looks like there's some solder joints that really need redoing, and it might be worth having the whole board properly inspected.  Unfortunately, without being able to stick a multimeter on it, and start tracing it all out, I'm pretty much at a loss now to help. I don't even believe I have a climate control board from an R33 around here to pull apart and see if any of the circuit appears similar to give some ideas.
    • Nah - but you won't find anything on dismantling the seats in any such thing anyway.
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
    • You don't have an R34 service manual for the body do you? Have found plenty for the engine and drivetrain but nothing else
