Just a quick question for those who imported their own v35's..
how long did it take to get to Australia?
including...time waiting to be shipped....time on the ship.....
reason I ask is..im importing my 2nd v35..and this time its been 2 weeks waiting for the "shipping schedule" to be announced...wtf? How long u guys had your v35's waiting at the port in Japan for?
cheers
Mine was bought from an auction and shipped and reached melbourne within about a month, but that was due to very helpful family members, but then its taken about 2 months now to go through customs and compliance because i imported a series 3 v35.
But have you tried to get in direct contact (phone not email) with who every is shipping the car from japan?
Yeah there was a series 3, i don't know how it was categorized but from what i can tell it was only 06 models, and there are 3 people in australia who can compliance them, 1 in Qld, 1 in Perth and now 1 in Melbourne.
Edit: I found some info about series 3
http://www.skylinesaustralia.com/forums/topic/331231-v35-series-questions/
Edited by DUSHED
hey thanks for that info man...im going thru a custom broker...so they are handling all the shipping for me...but I'm just wondering because its been like 2-3 weeks and the car isn't even on a ship yet...is this normal??
I did have to wait about 2 weeks for my car to get on a boat but I was told which boat it would be on and when it was leaving just a few days after the auction. '2 weeks waiting for the shipping schedule' seems a little strange.
yeh to this point I still don't know which boat my car will be on because they are "waiting for the shipping schedule" to be announced...
sounds sus right?
I thought shipping schedules are put on a website somewhere for everyone to see....
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
